Home Forums Bike Forum Self extracting crank bolts
Viewing 3 posts - 1 through 3 (of 3 total)
  • Self extracting crank bolts
  • Phil_H
    Following a ham fisted incident in the shed on Monday night which resulted in a rounded hex head I need to remove the alloy cap so, When removing the alloy cap with a pin spanner on a set of middleburn self extracting crank bolts is it anticlockwise to loosen or clockwise?
    julianwilson
    anticlockwise on both sides for those bits (its pedal threads and bottom bracket threads that are sometimes backwards)
    Phil_H
    Thanks, It’s a big enough cock up without tightening things up instead of loosening them.
The topic ‘Self extracting crank bolts’ is closed to new replies.
