Home Forums Bike Forum Roadies puzzle me sometimes.
Viewing 19 posts - 41 through 59 (of 59 total)
  • Roadies puzzle me sometimes.
  • 2
    scotroutes
    I’m not convinced clothing colour makes much difference but it depends where you’re riding. Dayglo.can be seen a long way off on straighter country roads but is a lot less visible in towns and cities.
    FWIW I tend to avoid black/dark colours for road riding but don’t go out of my way to be especially bright.
    Lights are more important. I use a Varia radar rear and a little Exposure front during daylight hours.
    The number of riders I see with no lights, after dark, always amazes me. When I worked at The Bike Chain in Edinburgh, Mark and I would often commute with a spare, new, set of lights and offer them to the unlit for free. Most weren’t interested; too fiddly, can’t be arsed fitting them, they’ll just be stolen, and “but they’ll just need new batteries” were all reasons given.
    matt_outandabout
    A good point.
    You can ‘blend in’ in a city with a surfeit of yellow high Viz, bright signs, etc etc
    I find ‘unusual’ colours are better in a city.
    I also agree that lights and reflective (preferably on legs as they move) are more important than colour of jersey…
    1
    ossify
    I definitely find bright pink or something more visible than yellow/green in a city (in daylight), as someone earlier said it’s contrast not colour. Pink is just that bit more unusual. Not that I wear it :-p
    At night, reflective stuff helps much more than colour by itself, unsurprisingly. Many of the schoolkids round here wear coats that look greyish but light up like a beacon in your headlights, brilliant stuff. Proviz I think is the main/original brand but there are plenty of copies around now.
    In general I share the opinion of “every little helps”. Will high-vis help when a driver doesn’t look? Of course not. But it will help for some drivers.
    Similarly (and not to get sidetracked!) will a helmet help when I get flattened by a speeding lorry? Of course not. Will it help in the much more likely scenario of a slow-speed collision with a left-hooker or someone stopping with their bonnet sticking out of a side road in front of me? Probably. So I wear one.
    crazy-legs
    I wear one (on the road bike) partly because, on a proper road ride it’s almost ‘part of the uniform’ and partly to avoid the newspaper report into my death reading “the cyclist, who was not wearing a helmet…..” and the associated victim blaming!
    Agree about the contrast comments. In town, another yellow hi vis is neither here nor there. I find blue or pink work well. I had one of those bright pink gilets for a while and my main commuting jacket was a bright light-blue colour which was something different from the normal stream of cyclists in yellow hi-vis.
    1
    scaredypants
    And the primary cue for detection is movement not contrast, so have a flashing light
    better strapping a light or reflective strip round your ankles
    Exposure Trace flashing on max front and rear
    I use a bright flashing rear light, because I want everyone to know I’m there but I feel safer if some of them are just not that confident exactly where.
    The 2 above are great – if you’re confident that uncertainty leads to caution.  One alternative might be that:
    Many of my closest calls have been deliberate close passes.
    1
    ossify
    Re. lights, I use 2 rear lights, one flashing and one steady.
    This is based on my own experience seeing others when I’m driving – I find flashing easier to notice (small steady red lights often get lost in the city surroundings, even bright ones) but steady is easier to judge the position/distance/speed.
    BlobOnAStick
    Smart LED Bike Light Pedals | Arclight PRO Clipless Pedals – Redshift Sports
    2
    ayjaydoubleyou
    A good point.
    as another point, on a country road with wet tarmac, green trees in the background with low sun/dappled light, I’ve seen the stereotypical retiree randoneur uniform of hi vis coat and helmet cover, with plain black leggings nearly disappear.
    Red would be ideal in this situation, apart from the red-green colourblind.
    pretty sure that almost no “proper*” bike complies with this, but pedal reflectors are technically required after dark. Reflective backing on the shoes is a good substitute. reflective pants clip for the urban commuter another good idea.
    (*a proper bike being one which doesn’t come stock with pedals from the shop, tongue firmly in cheek here)
    matt_outandabout
    MoreCashThanDash
    You can get reflectors that clip into SPDs to make them single sided – used to have them on my commuter.
    1
    bfw
    Its true a lot are dumb about dark night/miserable weather clothing.  I personally think riding on the road is an excuse to wear mad colours 🙂
    Pink or bright orange Rapha gilet, or coat with reflective bits all over on my night rides or bad weather.  My commute used to be reflective gilet and/or yellow goretex jacket.  Even in the summer I go for bright colours.  always ride with at least one rear light/camera in the day and two lights front and back at night.  Still have had the ‘didnt see you there mate’ !
    ransos
    As I was walking home from work, a driver went straight through a zebra crossing while I was waiting. I had a black coat on so it was my fault.
    1
    davy90
    I go with what I’ve observed to work as a frequent city driver. Front and rear light flashing at all times. Steady lights just blend in with city traffic. A white helmet is visible day and night.
    I have mostly dark cycling kit but do have reflective bits on shoes and top.
    I got T-boned from a sideroad once on my motorbike and more recently on my pushbike (low sun was blamed by the driver. I had my lights on my pushbike but they weren’t switched on)… Both in broad daylight….
    thisisnotaspoon
    Decathlon only do their roadie waterproof in a dark translucent fabric but otherwise it’s really good ?‍♂️
    I think I get the get the best passes riding solo in club kif (doesn’t work on club rides though).
    BadlyWiredDog
    I think light quality makes a difference. There’s a special time of day – just before dusk – when cyclists on the road become quasi invisible and anything that might up the chances of being seen is worth a punt, bright colours, lights, reflective. Ditto in rain / fog etc.
    In good visibility I’m not sure it makes much difference at all, but I ride always with a rear light and sometimes with a front. At night reflective stuff makes you super visible.
    I think you can get caught up in a lot of nuanced fiction about bright colours and the way drivers behave, but ultimately it’s always seemed to me that it’s better to be visible than not. Second guessing what preconceptions some random driver might have – and let’s be honest, ‘drivers’ are not some homogenous group, they differ wildly from one another – is beyond my remit / capabilities.
    So, I mostly don’t wear black on the road, particularly in low visibility conditions – dusk, rain, murk, night. But I don’t have strong views on what others choose to wear either.
    That said, I’ve chanced on – almost catastrophically – riders dressed in black, with no lights or reflective in the pitch dark. That seems daft.
    1
    MoreCashThanDash
    At night, I’m legally required to have lights, so I do. I can see and be seen. I’m also legally required to have some reflectors on the bike, but I make sure I have some reflective on me instead. Proviz overshoes are amazing and horrendous all at once.
    Daylight I’ll also use lights, and don’t worry too much about clothes. Most of my kit is a pretty solid block of some colour or other, so will stand out against some backgrounds at some point. Nothing will work in all conditions, so I don’t worry about it and I don’t worry what other cyclists wear. Their choice, their risk.
    1
    poly
    That’s one way to draw attention to yourself – but it’s a bit too chilly round here for that!
    thisisnotaspoon
    I was thinking that actually what’s needed is an inverted high-vis.  A “high-vis” gilet blends into the leaves and hedges, whilst black leggings blend into the road.  What you really want is bright yellow leggings and a contrasting top.
    But yea, I was on one of those motorcycle accident reduction courses run by the police and their take was that nothing works all the time.  If you’re riding down a treelined road in autumn with strobing lights and yellow high vis feeling invincible then you’ll get hit because actually your jacket matches the leaves and your strobing light just looks exactly like the dappled sunlight poking through the branches. In that scenario you’d be better off in all black.  At the same time, if the car is outside the woods looking in, the lights stick out more because they contrast (from the drivers perspective) with the dark woodland.  Same rider, same gear, same place, completely different levels of visibility depending on where the car is coming from.
    Think about whether the driver has seen you as well as whether they can.
    1
    mattsccm
    It’s the MTBers that concern me. Any rear lights are covered in muck, they have huge blinding lights, including helmet lights on the road and wear black, covered in mud.
