Home Forums Bike Forum Road advice – avoiding "bouncing" at high cadence
Viewing 26 posts - 1 through 26 (of 26 total)
  • Road advice – avoiding "bouncing" at high cadence
  • atlaz
    I’ve been doing workouts using TrainerRoad recently and at higher cadences 110-120, I find I feel I’m bouncing a little. What’s the best way to avoid this. Thoughts from me are:
    1, Saddle height (a touch down maybe?)
    2, Practice
    Or am I way off?
    rkk01
    change gear?
    soma_rich
    I used to get this when I started singlespeeding. I think its to do with carrying the pedal stroke around rather than just pushing down.
    asterix
    just get used to the high cadence – it takes practice for your muscles and brain to get used to it
    but actually I never find that in practice I get to such high cadences on the road – maybe 115 for a very few seconds at the most. usually I ride between 80 and 90
    scaredypants
    go up a gear ?
    (I bounce at 75, I think)
    atlaz
    There’s some parts of the warmups where you are supposed to ride at a higher cadence but also there’s been times when I run out of gears down long hills in the mountains where I’m aware that I’m bouncing a little so in order to feel a bit more stable at 40-50mph I’d like to work out how to stop it.
    eyerideit
    Do you mean your head/body bobbing up and down or the whole body bouncing on the saddle?
    atlaz
    Whole body really. It starts probably around 100. Used to start earlier so I think it’s just a case of getting used to spinning faster and really focusing on the pedal action.
    eyerideit
    Soma has it, you’re stamping on the peddles and not peddling in circles i.e. smoothly
    JoB
    make a conscious effort to plant your bum
    make a conscious effort to spin smooth circles with your feet
    make a conscious effort to use all your leg muscles, not just the pushing down ones
    practise
    cp
    Put your seat up, not down.
    As you get a better pedalling technique, you will bounce less. Concentrate on smooth circles.
    dirtygirlonabike
    Practice. I have 30 sec cadence drills to do ie 30 sec high (105) 30 sec higher (115) 30 sec max (125). I’m fine until I hit 125. The first two times i do it, I bounce at 125, but it smooths out after that, and by the 8th, its a smooth stroke. My max cadence has risen by 5 doing these drills.
    Changing to harder gear defeats the purpose of ths kind of thing. Thinking about pedal stroke helped me.
    stevied
    RP23 with pro-pedal?
    MostlyBalanced
    Ride singlespeed everywhere and have a beer or two.
    Straight out of the pub I managed to hold 20mph for a mile and half on 36:17 when my mates thought it would be fun to try and leave me behind on their geared bikes.
    pedalhead
    I may be making it up, but I feel that I spin more smoothly at high cadence when my core is stronger.
    headfirst
    I’d say seat up a tad too.
    and for this:
    Stop pedalling. And concentrate on being more aero if you feel the need to go faster. I’d argue you’re going fast enough though
    DenDennis
    yes- don’t change ride position if you know you are at the right long-term setup.
    I believe practice and engaging the correct part of core is the key.
    It sounds counter-intuitive but if you actually push away on the brake hoods rather than pull, it can help to get it right- try it! 🙂
    Rorschach
    eyerideit
    Rollers are great for learning how to pedal smoothly and strengthening your core.
    And Ned Overends book has a good section about peddling in circles. HE recommends finding a slight gradient and using one leg to pedal.
    eyerideit
    That’s what I learn on rollers push back and lock your core
    D0NK
    fixie long steep downhill problem solved
    either you end up tres souplesse or your body is so mangled you’ll be worrying about walking again rather than hitting 130rpm
    Dyffers
    2. Practice.
    Ride (road) fixed in the hills to force yourself to spin at an uncomfortably high cadence.
    That will sort out your pedalling style (or kill you) after which you’ll be able to chase the pawls on a singlespeed (on a smooth the road) up to about 150rpm for a minute or two without bouncing.
    EDIT: as D0NK wrote whilst I was typing.
    atlaz
    Well, down the really steep hills I usually don’t pedal, I just concentrate on not screaming or hitting something but there’s a few hills I’ve gone down recently where there’s no side roads, great visibility and I’m able to keep up with traffic but once I hit (at the time) 90-100 revs I started to bounce and get a little unstable (this was in the drops). Doing it over the last few nights on the turbo brought it to mind again.
    glupton1976
    Get a bit more resistance on there. My max is around. 190 if I have the resistance correct or 120 if i dont.
    D0NK
    BTW I’ve never tried the method I suggested, I’m too much of a scaredy to ride fixed but read quite a few people recommending it so thought I’d mention it 🙂
    brakes
    ^^^^^this
    there’s not an obvious technique, but it seems to me to be about holding your body (core) taught to keep you planted, but having your legs really supple so they’re spinning and not lifting you off your seat.
    I’ve got some steep bumpy downhills on my commute – riding them on a fixed wheel is a real challenge – like riding a bucking broncho.
The topic ‘Road advice – avoiding "bouncing" at high cadence’ is closed to new replies.
