Esme – Member
While you’re waiting for Amplebrew to wake up, there’s some interesting stuff here
That link above is spot on and shows some of the popular routes over here.
The Southern Comfort Loop is really good which you can join a short riding distance from Peel at the path that leads past Kerroodhoo Plantation just off the A27 coast road south of Peel.
The Hells 8 route is also recommended and you can start this from Kirk Michael which is just North of Peel and only just under a 7 mile ride north from Peel.
I would also definately make contact with either somone from the Loaghtan Loaded or visit the Manx MTB forum[/url] as there are numerous rides throughout the week.
If you’re wanting to get from Peel to South Barrule, there is a nice route that leads from Peel harbour through to St Johns which is the old railway track. From St Johns you would then have a road ride thorugh to South Barrule. This would only be just over 6 miles each way.
You can also ride over Peel Hill past Corrins Tower from the harbour, dropping down into Patrick near to the Raggatt, the take a route just off the A30 in Patrick which leads upto the old mines and then onto South barrule.
Or you have the option of riding on the road for a short distance to Glen Maye once you’ve dropped down into Patrick from Peel Hill, taking the path through Glen Mooar that ends up at the Round Table. You then go onto the ‘Whiskey Run,’ which is marked off as Bayr ny Skeddan on the OS map and get access into South Barrule from there.
What dates are you over?
