Home Forums Bike Forum Replacing shimano lever blades
Viewing 4 posts - 1 through 4 (of 4 total)
  • Replacing shimano lever blades
  • lornholio
    Had a silly crash today and bent one of my Zee lever blades badly – pretty surprised it didn’t snap.  I have an old lever with a broken reservoir cap that I’m going to try to swap the lever blade over from – seen a few posts on MTBR and Pinkbike saying it’s possible just a little fiddly in the reassembly step.  Also found the tech document with exploded diagram for my specific lever.
    My question for anyone who has done this procedure: do I need to disconnect my current lever from the hose or can I do it while all connected?  Saving a few steps and a bleed would be nice.
    Any tips to make reassembly easier would be good too.  I’ll probably dismantle and reassemble the old broken lever first as a test, might all make sense but might not.  Hopefully can fix this tomorrow morning and get a ride in.
    Ta.
    sillyoldman
    Possible while connected. Easy job – remove grub screw that locks the axle in place – drift out axle, then reverse to fit new lever. Seating the wee spring to prevent lever rattle is the only vaguely awkward bit.
    lornholio
    You’re not kidding.  Just had a trial run removing the blade from my spare old lever and reinstalling it.  Ended up making a little dowel the right size to hold the pieces together while inserting them into the lever body, then used the axle to push out that dowel.
    Having done the above I can see how it’ll be no issue to do it on the bike.  Enough for tonight though, that’s a job for the morning.
    Thanks.
    lornholio
    Fixed the lever now 😊.  Pretty straightforward, just a bit fiddly.
The topic ‘Replacing shimano lever blades’ is closed to new replies.
