Home Forums Bike Forum Removing gorilla tape residue
Viewing 40 posts - 1 through 40 (of 44 total)
  • Removing gorilla tape residue
  • tall_martin
    Hi,
    I’ve been gorilla taping my tubeless rims for 10 years. The residue removal has always been mildly annoying.
    This time the tape has refit residue round half the rim.
    Ethanol isn’t shifting it.
    Sticky stuff remover ( TM) isn’t moving it.
    Elbow grease with tire levers, cloths gorilla tip to lift it isn’t shifting it.
    Half an hour and I’ve got 5cm partially clean
    Any suggestions.
    I’m getting close to just taping over it.
    Robz
    Rubber eraser drill attachment?
    goo-gone?
    sharkattack
    You’re supposed to put electrical tape underneath it. Full tubeless functionality with zero residue.
    1
    Tracey
    I’ve had success in the past using a hair dryer to warm it up but it’s a two person job
    Tend now to use Specialized 2Bliss Ready Rim Strip as it works better than anything else I’ve used
    1
    ajantom
    Came to say exactly this ^
    Obviously not much use right now though!
    If you’re retaping with Gorilla tape, just tape over the residue.
    oceanskipper
    Petrol will shift it I expect…
    stumpy01
    GT85 on a cloth works for me, but you then obviously have to de-grease the rim as well.
    Kramer
    WD40 point cleaner did it for me. Loads of it on a non linting cloth. Still takes some elbow grease and I was high as a kite by the time I’d finished.
    1
    MSP
    Tesa 4289 is stans tubeless tape, comes in 65 metre rolls for around 10 quid. Why bother with the faf of gorrila tape when better alternatives are so cheap.
    Tesa 4289 Tubeless Bike Wheel Rim Tape
    Kramer
    @MSP thanks I’ve made a note of that link.
    fooman
    Warm it up with hairdryer, once you pick some off roll it into a ball to dab more off. Comes off quickly and easily that way, not that I’d ever use gorilla tape for tubeless again.
    1
    Northwind
    Petrol is about the best for this ime, but it’s still horrible.
    sharkattack
    Or, just don’t use the gorilla tape. Electrical tape is a perfectly good tubeless tape by itself.
    noeffsgiven
    Washing up sponge soaked in GT85 has never failed at removing stubborn sticky residue for me, it keeps the GT85 on the surface better than a rag or paper towels, I spray it on the rim first and rub it in with my thumb so it gets to work soaking into the sticky residue.
    quentyn
    You might have more luck with a more aggressive solvent such as acetone, ethyl acetate or also try lighter fluid (works well on silicon oil and lipstick)
    If ethyl acetate doesn’t shift it then just tape over it
    escrs
    One of the above is the best, the one time i did use Gorila tape without electrical tape i ended up removing the residue by doing the following
    Warm up one section of the rim at a time using a hair dryer, this gets the residue nice and sticky, then i got a thick cloth glove and went over that section getting off as much residue that would stick to the glove, then with a fresh glove cloth i went around again after soaking the finger tips in Isopropyl alcohol, this seemed to clean off the left over residue
    1
    pisco
    IPA + time + elbow grease.
    Northwind
    Oh yeah you can get good results rubbing it off with a thumb, it’ll ball up and stick to you as much as the rim and then you can wipe or flick it off… but be careful, it’s very very easy to blister yourself- localised surface heat I think?
    Saccades
    Disc brake cleaner.
    Pissed.
    1,1,1, trichloromethane
    dyna-ti
    Wool. It really works.
    Trust me 😉
    oldnpastit
    I had some success with swarfega of all things.
    tall_martin
    Thanks!
    I have lighter fluid, I think I’ve got a can of petrol for some hedge trimmers, I’m out of swarfega and I’ll borrow my wife’s hair dryer.
    I used some Tesla tape on another pair of wheels. It was significantly better than gorilla tape.
    I bought some muckoff stuff and used that on another rim- it went on brilliantly.
    Unfortunately the Tesla tape and muck off tape I have are both too narrow for this rim.
    1
    anderzz
    Autoglym tar remover. Quality stuff.
    sweepy
    Multisolve, if it gets rid of CT1 it should shift anything
    prettygreenparrot
    Propan-2-ol?
    submarined
    Tesa tape is great if you can get it to stick to the rim and conform to the contours. I found it a right **** to use with runs with a pronounced centre well.
    If your reapplying monkey tape, just put it over the top, always worked for me. I’ve found if I just rip the tape off it leaves loads behind. If I remove it slowly it leaves far less.
    I’ve taken to using Gorilla tape to seal, then a layer of electrical tape over the top as a sacrificial thing. Then it doesn’t pull the Gorilla tape off when I change tyres.
    kormoran
    Coleman fuel or primus fuel is nicer to use than petrol
    Weirdly bicarbonate of soda works well with sticky residue. Rub it on, the gunk balls up and sticks to the soda then drops off as it loses it’s stickiness. I’ve used it loads for getting residue off surfaces, tape and stickers especially
    Northwind
    tall_martin
    Mentioned this above but it bears repeating, one thing to note is that a lot of rims don’t need to be taped full width- a welded rim (which most quality rims are) is already airtight except for the holes. That didn’t used to matter much, but modern rims got so wide that often you can simply tape the middle, in the recess, and not tape the parts where the tyre touches at all. This works miles better, because since the tyre doesn’t touch the tape, it doesn’t get stuck to it, and there’s no chance of it pushing the tape off as you remove the tyre- #1 reason for having to retape a rim ime.
    Most of my rims now are done this way, just 2 wraps of PVC/electric tape in the centre recess, wide enough to safely cover the holes but not wide enough to contact the tyre. You basically never have to redo it unless you break a spoke.
    (there’s no middle ground here though- if the tape’s not as wide as the tyre, but wide enough that it goes out of the recess, then the tyre will probably tear the tape off the first time you remove it)
    View post on imgur.com
    scaredypants
    I’ve never had to but I’m guessing that warming and then using a length of new gorilla tape might pick up the residue
    scaredypants
    ((working on a diagram))
    greatbeardedone
    I guess all the above suggestions involve using an acidic solvent.
    Bicarbonate of soda is very mildly alkali and is available from any supermarket for 60p.
    works great at deodorising shoes, too…”do the skake and vac”👍
    fooman
    Seriously, put away the aggressive chemicals and warm it up with a hairdryer, then it comes off dabbing with a bit of picked off residue or the sticky side of another bit of tape.
    BadlyWiredDog
    In true, contrary STW spirit, could I just unhelpfully suggest Mavic UST rims that don’t need tape at all?
    But hairdryer has worked for me in the past. Heat and rub off.
    tall_martin
    That is an excellent diagram 😃
    tall_martin
    I have some Mavic ust rims- great wheels.
    Unfortunately they are 26″ and al my MTB are 29″
    jameso
    Is it anything like normal 3M gaffa tape residue? I’ve used 3M and Gorilla tape and don’t remember the residue being different. I find GT85 gets rid of gaffa tape gunk better than solvents anyway. Of course I tried the solvents first .. then tried GT85 when solvents didn’t work. Messy job still, need plenty of clean cloth to remove what the GT85 loosens.
    mattsccm
    Petrol takes everything off and is cheap.
    1
    chakaping
    +1
    That’s a Gorilla tape-only rim now.
    Also +1
    PrinceJohn
    Have used Gorilla tape in the past & it works brilliantly – tried the tesa stans equivalent I wasn’t impressed at all. It’s cheap but it’s not got the same stretch & pliability that Gorilla tape has
    BillOddie
    This.
    tall_martin
    Thanks
    Went to use lighter fluid- couldn’t find it
    Gt 85- can was empty
    Petrol- working well. 30 min of scrubbing with a cloth and it’s half done
