Home Forums Chat Forum recommend me a foldable saw
Viewing 15 posts - 1 through 15 (of 15 total)
  • recommend me a foldable saw
  • tom84
    for trail maintenance you understand! also i'd like to know where to get one on the internet that is reliable and good
    chars
    scruff
    The Silky range are superb. You really can cut through whatever very quickly. The expensive ones are stupidly good, 8 inch fallen trees despatched with ease.
    http://www.buxtons.net/arborist-handsaws.irc?cName=arborist-handsaws&pg=1
    MrCrushrider
    i use a gerber lock saw, cost about £20 i think. very good at what its made for. cant remember where i got it though sorry!
    sqwheeler
    Silky Fox[/url] really are outstanding. Sharp as a sharp thing that's just graduated from whetstone university with a PhD in honing. ahem.
    redthunder
    Aldi
    Wilkinson's (Cheap Shop)
    Last ages and believe me I've cut down loads of stuff.
    scruff
    After owning a cheaper B&Q one then a Silky the more expensive ones are worth the extra IMO if you are using em a lot.
    myheadsashed
    bahco laplander………….good enough for Ray
    skidartist
    Axminster[/url] do some Japanese pull saws quite cheaply, some fold, some allow the blade to separate from the handle (keep the cover for the blade so you can pack it in a bag). Very thin kerf as the blade is in tension when you cut, so less effort in the cut and weighs nowt.
    aviemoron
    Bahco. Used one for years to cut through trees, muddy roots, you name it, still sharp.
    Shandy
    good enough for Ray
    Does that mean good enough for whipping up a delightful wild mushroom omelette in Epping Forest?
    timber
    Silky Fox – professional items, replaceable blades and plain bloody good
    mcmoonter
    Bahco Laplander + 1.
    Tried the Gerber, I think they use the same foil they wrap up chewing gum with to make the blades from. I've cut through 5 inch branches with the Bahco, its still sharp, seems it will last for ages. The Gerber was pants by comparison.
    tomh
    Silky F180 is an amazing little saw, mine didnt cost too much either
    tom84
    great response guys thanks!
    i'm thinking of either the silky f180 or the accel. i think the one i broke (which was borrowed, doh!) might have been a wilkinsons jobby
    redthunder
    Let the saw do the work 😉
The topic ‘recommend me a foldable saw’ is closed to new replies.
