I’ve just got my first rear air shock. Always had coil. It has two valves. The manual for the shock is missing information. Tried googling, but keep seeing stuff like “equilise the air pressure”
Frame is a Ghost Lanao FS, came with a DNM AOY-36RC.
Manual states main air chamber takes upto 250psi, and that the negative air chamber takes 50-80psi. Obviously I can’t equalise manually when there are two volumes. Putting air in the main chamber is easy and precise the negative air chamber is finicky.
Manual states how to get sag with the main air chamber, but nothing at all about the negative air chamber.
What should I be doing here? Going to take the bike out tomorrow to setup the gears and get used to it. Don’t want to damage the shock or bend the shock spacers.
