Home Forums Bike Forum Rain, rain, rain- Kielder 100
Viewing 40 posts - 81 through 120 (of 153 total)
  • Rain, rain, rain- Kielder 100
  • radoggair
    they could make it 100,000 and it wouldn’t be beaten.
    I would also like to think that the fast guys doing it were most of the best in Britain just now. Sure there was no Matt Page, neal cramptons etc but over 12hrs we still had the Ant White’s, Rothwells who stay pace with these guys and we were’nt getting near 8 nevermind 7hrs. For Ben to get 8 was amazing enough but in perfect (for kielder) conditions only a cancellera bike could get him near 7hrs 🙂
    numplumz
    With respect there are many faster racers in the uk, than the names you mention, never mind Europeans.
    The course was actually shorter this year, I made it 99.6 miles which makes comparisons tricky, I was actually faster at 9hr50 this year than in the dry last year, must have been the lack of brakes :-).
    Also can comparisons be made when a large group of lead riders can actually increase the speed if they work together, every year is different.
    Heard several riders comment how they were right up there until [insert problem] made them lose the tow.
    Well done to all the marshals and Helpers in that weather, not an easy day out.
    thomthumb
    really didn’t got well for me.
    brake pads were contaminated and the grit seemed to seize my remote lock out so the forks were locked out permanently – death grip has left me with visible bruising on my palms!!
    had a small spill and then later on a big crash at about 55km whichleft me in a lot of pain limped on and missed the first checkpoint by 15 mins – i was going to turn back anyway.
    unfinished business +1.
    Leachy
    Pads gone at 33 miles, stuck my first spare set on the rear (kevlar). They only lasted 18 miles, did 51 to 62 with no brakes and made the second cut off with 8 mins to go. Cake in gob, grabbed 2 sandwiches and then squirted as much lube on my chain as I could. Didn’t have time to get any water and they wouldn’t let you check in and then go back to fill up. Made it to the 78 mile point but missed the cut off, definitely got the bug looking forward to next year.
    Longest, wettest and hardest ride I’ve ever done.
    Oh and chain suck………. sucks!
    large418
    numplumz – you had a cracking ride! Better time and placing than last year even though the course was 3 miles shorter. Saw you at the 1st stop then you pulled out lots of time on me.
    Does anyone have the secret of long lasting brakes? Whilst walking the dog today I was think of some disc shield that encases the disc and caliper. Not much good for airflow, but good for a wet horrible course like Kielder where brake cooling is not an issue. Or are there some secret carbon based pads that last forever? (My Hopes are through the backing plates on their 2nd set of pads – the piston popped out of the fronts so they didn’t work as the fluid was leaking out).
    I didn’t bother with any chain oil at the tech stops as firstly it just washes straight off, and secondly the water acts as a lube (but the sand doesn’t!).
    I might have a look inside the forks tomorrow to see how the seals/oil has fared.
    uplink
    I pulled the lowers off my new [2012] Fox forks last night and they were as clean as a whistle so it looks like the SKF seals they use now are pretty good, I can’t imagine doing rides in worse conditions than Kielder threw at us so fairly confident they’ll last well
    The drivetrain [10 sp XT] has faired reasonably well too with no obvious wear visible
    The paintwork has suffered somewhat but it’s a mountain bike after all
    AndrewBF
    Wow. Incredible effort from all participants. I bailed this year’s race – and in retrospect am pleased I did, it would have been very mentally tough to do all the prep only to be destroyed by the weather. Last year was tough enough and that was in the dry :S
    Do the midges keep away when it rains? Perhaps the blessing is that you aren’t being eaten to death on the circuit when it is wet. 🙂
    Next year…
    mrlugz
    The bites on my legs would suggest that they put their waterproofs on.
    swedishmatt
    Wouldnt normal old school rubber brakes work better, albeit with poorer braking power?
    nobber
    Churned through 2 sets of shimano pads by the half way point so with just one set left resigned myself to not being able to finish, took a nice long lunch break at Newcastleton then pushed on to the 68m cut off for a lift back, turns out the cheap Superstar sintered I had left lasted the final 50mile with plenty to spare, the last 20miles was a blast once I realized I would finish after all!!
    richmars
    Can we somehow capture what pads worked well? May be also include what bedding in (if any) was done.
    njee20
    There’ll be no consistency, otherwise we’d all use that type of pad!
    I’m with Numbplumz here, Ben’s a superb XC racer who made Kielder his goal. IMO a race like this doesn’t necessarily favour the endurance specialists, not in the same way as a 24 or even a 12. With a favourable course and good weather I’d not be surprised to see 7 hours, although I definitely agree it would be a phenomenal ride. I’ll see what Ben reckons!
    t-p26
    I was there as my mate from the other end of the country stayed at mine with his GF before and after.
    We went to several “spectator points”, I ended up fixing brakes and fettling(dry warm hands work way better than wet cold ones) then proceeded to ferry retirees back to the the start. Hats off to everybody who even started the event, it was gopping @ 06.30 and was forecast to stay that way.
    Numplumz, you were by far the fastest I met when doing my IR bit on the road section from Bloodybush pillar down to The Forks(78mile cut off)well done to you but TP dust is still more preferable…..
    BTW Kielder: just not for me thats all!
    senorj
    What a ride ,3sets of pads used.4 would have been better. I had a nasty off @50 miles-couldnt stop on a corner!
    Well doneto all who started. The marshalls were amazing,especially the next to last dibbers who gave me a push!
    Special mention to fella called greg who checked i was ok after the off ,ta. Oh,and the lady with the pink brakes
    who dragged a few of us up deadwater past the piper.nice one. And the fella who was doing his first ever mtb
    race.in at the deep end! Good banter all round.
    My only disapointment is that i didnt beat last years time,have to do it again now!
    I havent told senorita J yet.Ha.
    jimmers
    Six sets of pad wore out for me. KIA list for pads is as follows.
    – 2x Superstar Kevlar (bedded in, almost new)
    – 1x Superstar Kevlar (new not bedded in lasted 5 miles)
    – 2x BBB Sintered (new not bedded in)
    – 1x manufacturer not known (part worn)
    Many thanks to the lady who lent me two used pad at the Newcastleton otherwise I wouldn’t have been able to finish, hope the gels got you to the end!
    For the last 38 miles I had two sets of pads, so I just used the front brake and replaced these when they went which was on the last 1 mile from the finish at the top of the swoopy downhil red section into the finish.
    I didn’t bother with gears so other damage to the bike was limited to a sticky lockout lever and a rusty chain.
    Really enjoyed it so will be back next year with more (bedded in) pads.
    Also thanks to all the marshals and organisers. The support and organisation was superb.
    Edit:
    Also thanks to the other riders who helped support at the different checkpoints after retiring due to mechanicals and mishaps. A bit of banter and encouragement goes a long way in getting your head together for conditions like that.
    bomba
    Hung with a group up till the first feed station, but carried on whilst they stopped to refill bottles. From there I ploughed on solo all the way to the finish – not fast enough to catch anyone in front, not slow enough to be caught. Barely saw another rider all day.
    Finished just outside the top 10. To go any faster, I think I’ll have to try and hang in a group with some of the fast boys. And maybe eat fewer pies 😛
    wool
    1 Set superstar reds till Newcaslton and changed to aztec sintered they lasted till kielder with loads of life left in them.
    jimmers
    Had a look at the results.
    Does anyone know the distances for all the checkpoints listed on the results (CP1, CP2, etc)?
    Forge_Master
    My first attempt this year and I missed the 51 mile cut off by 2 mins. My initial feeling of upset soon moved to relief and if i’m honest i wouldn’t have made the next one as i was mentally drained.
    A big respect to everyone that lined up and massive respect to all the guys that finished. I just can’t comprehend some of the finish times, in those conditions that truly was a great achievement.
    Also a big thanks to the marshals and tech guys who were out in that weather probably longer than most of us and also the organisers. It was a great event and I for one will be back next year come rain or shine.
    budge
    Very rarely post but just wanted to express my thanks to the organisers for putting a great route together. Tough course but lots of rewarding singetrack sections that helped to keep spirits up in the miserable conditions. Great marshalling with loads of encouragment from them all. Also a big thanks to all those who passed and gave me an encouraging comment. 11.5 hours and 66th place (23rd MV) – happy with that. Not sure I will do it again but I’m bound to reconsider in a few weeks time when everything has healed.
    Budge (the Team JMC one).
    uplink
    I won’t be going back, it’s a better race than I am a rider, that’s for sure
    Tried it 2 years running now, first year I was 8 mins outside of the 1st cut-off, this year I was 30 mins inside the cut-off time but had run out of brakes by then and – TBH – I was relived to have to call it a day
    I trained as hard as time allowed me this year with 4 sessions per week most weeks and still it beat me, I know when to take a hint 🙂
    miketually
    Joolze has the photos up already: http://www.joolzedymond.com/joolzeD/Kielder100-11.html
    That’s my bars/hand in the thumbnail 🙂
    mrlugz
    the lad with the midge candle is my mate. We were midge free!
    Dyffers
    On Friday I was glad I’d chopped in my Kielder entry as my right achilles still hadn’t recovered from the week before.
    Now I’m disappointed I didn’t go as I love watching others more miserable than me in bad conditions!
    Respect to all those that finished. As much mental straength as physical by the sounds of it.
    michaelmcc
    jonba – Member
    I’ve just finished checking my bike to see what work needs doing.
    New jockey wheels – no teeth on any of them
    new cables
    new pads
    brake overhall including new pistons*
    New rotors*
    new chainrings
    new chain
    new casette
    new bearings for hope rear hub
    so expensive race
    What the hell?? Really? You must have started it on a slightly battered bike to make it in that state?? Unless all your gear wasn’t set up properly maybe.
    michaelmcc
    Yeah it was about 103 or 4 miles the past two times i did it. Would have liked to see Crampton there.
    Pyro
    A massive shout to anyone who turned up and have it a go, I reckon!
    I was marshalling, firstly at the end of the first (Wainhope) loop, about 25 miles in, and even there the atrrition rate was high, the retirals from the first feed station onwards were even higher. We radioed every retiral back to control, Sara’s radio traffic was absolutely non-stop all day.
    Comedy sight of the day was from my second MP, at the curved bridge at Lewisburn, the number of people pinging off the railings or sliding down with a foot in their fork arch to stop was brilliant! Given the circumstances, had it been me, I think I would have pulled out, serious respect to everyone who gave it a shot.
    michaelmcc
    To all the people going through so many brake pads and wearing them out after 13 miles etc, i have two theorys. Either you’re using cheap seven quid jobbies, or just braking far too much.
    I’ve done it the past few years on one set of pads, and a lot of life left in my other components.. apart from the cables maybe.
    How did the route compare to the last two years anyway?
    mrlugz
    Other than bearings and chain rings, that’s my list of repairs too. My rear mech was brand new and the jockey wheels are shot, chain was new, pads new cables new.
    But when you are trying to slow down using your pistons onto your rotors, it makes a bit of a mess.
    singlecrack
    This is true but unless you were in the leed bunch you were in a pack of about 100 plus for the first 20 miles, so its like your in a trafic jam on/off the brakes all the time
    jimmers
    Sounds about right, the majority of my pads went in the first 30 – 40 miles of the race. I started at the back so there was a lot of traffic to contend with.
    tlr
    The problem isn’t braking too much – its actually not a very brake intensive course. The problem is the lack of clearance of calipers and the kind of sticky dirt up there.
    After I changed my rear pads at 60km I must have lost all my hydraulic fluid or something as the lever was just going straight to the handlebar, so I didn’t touch my back brake again. My rear pads were still down to the metal by the end!
    Somebody (Hope?) needs to invent a wide clearance caliper so that the pads sit way off the rotor when not in use.
    miketually
    I used to set my Avid BB7 mechanicals up with a lot of clearance, as they’re manually adjusted.
    The brakes on every bike I rode near to were making horrendous noises constantly. Remember the sound when riding through mud with V brakes? Like that.
    jonba
    I was dragging my brakes, that’s why I got through so many pads. In fact everyone was dragging their brakes. If we had all known how to ride we’d have been fine on part worn organics obviously 🙄
    njee20
    With all due respect to Neil, Ben’s a better rider and has made this his goal for the last few months, several training camps in the Alps and what not. Not to say he wouldn’t have pushed the pace a bit more though!
    The more horror stories come in the more glad I am that I wasnt there, and chapeau to the finishers!
    c_klein87
    Top event and major thanks to the marshall’s, first time for me and i was 4th (i think) singlespeeder back, just need to change the pistons in my brakes….
    SSS
    Big thanks to the organisers and marshals 🙂 Course was like a Summers Strathpuffer but without the snow!!!
    I started off with new (bedded in) rear sintered, and used front resin. Had to change fronts at the ‘piper’ to sintered. No more pad changes after that.
    Came into the finish just before 13 hours…….
    thomthumb
    my pads don’t look at all worn. fronts new and rears 1/4 worn. they might be contaminated – they didn’t work. so maybe that’s the trick 😉
    paul4stones
    See the thing is I would have agreed with you in the past. I have ridden at Kielder, in the rain, for miles without any pad problems and completed the first two events without a change. For some reason it was terrible on Saturday – I got through 3 sets in my 80 odd miles and the fronts were new at 50 and down to the metal at the end. I thought the conditions on the ground were not that much worse than the first year – it rained more but as drac said above it was only about 1cm which is little. Baffling really but in a way I’m glad I didn’t renew my drivechain before the race 🙂
    michaelmcc
    True. I got caught behind someone two years ago who was hugging their brakes the whole way down one of the long twisty descents, so i had to slow down to save ramming into the back of him. That’ll wear down your pads!
    There are some terrible brake huggers out there. Conditions make a big difference though obviously.
The topic ‘Rain, rain, rain- Kielder 100’ is closed to new replies.
