Home Forums Bike Forum PEAKS POOTLE: feb 19th, white peak
Viewing 40 posts - 161 through 200 (of 300 total)
  • PEAKS POOTLE: feb 19th, white peak
  • Bunnyhop
    Quite rocky in places, though a lot of the ride is on tarmac.
    beefy
    How rocky though? It’s that my mtb is a 6 inch travel job, sounds a bit much for this ride.
    I don’t mind the odd rock or two.
    will
    Naa I was only joking 😆 You’ll be fine on a CX bike, certainly fine on a SS
    Bunnyhop
    No real rocks until half way point, these are loose and ranging from small pebbles to small babies heads, this is a climb and then a lovely descent.
    Next rocky section is an uppy bit, mostly small stuff, then one other rocky downhill, mostly slabs with small loose stuff.
    Now I have to report, there has been an awful lot of water damage from the rain over the last couple of weeks. Things I used to ride have become tricky/much fun.
    lowey
    Right. Following the removal of my parental duties this weekend, I’ll see you lot on Saturday.
    tollah
    MrsTollah will be at work BH 🙁
    I’ll bring whatever bike is easiest to get out as I won’t be fighting with them all that time of the morning!
    nbt
    It’s fine on a singlespeed, one or two of the climbs are really testing and I didn’t make them last time I tried, but I *have* done the whole route SS before now
    6″ travel will make the descents a LOT faster. CX will make the descents more, umm, interesting and challenging…
    robdob
    You forgot to mention its also a shonky piece of tat that weighs as much as a small moon, looks like someone attacked it with a skip full on anvils and rattles like a granny full of spanners. 😉
    I might put my new uppy downy seatpost on to make my bike completely unsuitable.
    robdob
    Who was it that rode the Edale loop on the SS cross bike? Seriously dude you have lots of skill or bottle or both. I thought I was going ok on my Pitch when you passed me with a complete lack of respect for your own safety it certainly looked “on the edge”. 😉
    BadlyWiredDog
    Honestly, 99% of this route you can ride on just about anything. The only iffy bit is the top section of the descent into Buxton which is basically a messy rockery, though you can pick your way through it just fine. I’m a slow, technically inept rider and I’ve done it singlespeed, geared hardtail, 120mm full sus and 140mm full sus and all were fine, just varied a little in smoothness. You will be okay whatever you choose to ride.
    It’s actually a really nice route on a singlespeed fwiw, one mildly steep climb that’s hard because the surface is mostly rubble and thus traction is at a bit of a premium, but that’s about it. Oh, and the first haul out from the stream, which is a pig on a singlespeed with cold legs… or for me anyway, but then as above, I’m slow and weak and ill etc. Blah…
    will
    robdob – Member
    Some stupid nutter I think.
    amodicumofgnar
    The Buxton Baby Heads descent is definately the most technical bit of the ride but there’s usually a smooth line through. Often next to the fence but does move round – so dont wear posh jackets or blame me if its somewhere else.
    Going the guide book way round or figure 8 it to take in the track to Fernlee Res and over the dam?
    nbt
    Not familiar with the figure 8 loop – you mean from the White Hall centre, dropping over the ridge to Long Lane? Or something else? Been meanig to try that for years, and doing the old road through Rake End
    singlespeedstu
    Mmmm.
    We might come to this if there’s going to be some tandem action.
    That’s if you don’t mind another couple of tandemists trying to steal a bit of tandemattention? 😉
    nbt
    It’s be great to ride with some experienced tandemeers and pik up some tips 🙂
    Will this be the first official TURDS meet then?
    singlespeedstu
    experienced tandemeers 😆 😆 😆
    We’ve not even been on it for about six months.
    So that’s perfect training for riding it in front of a large group of people then. 😉
    nbt
    SOunds like you’ll fit right in. Who’s riding with you? Are you captain or stoking?
    singlespeedstu
    I will be captaining and thewhiteshoeracer will be stoking.
    Though she seems to have hung up her white racing shoes these days…
    Tandemshore to the power of sik. Or something like that. 🙄
    [/url]
    Mincy[/url] by sheldonattwood[/url], on Flickr
    Bunnyhop
    That ^^^ takes such courage.
    Does your stoker scream as much as I?
    singlespeedstu
    I have no idea how much you scream. 😆
    Generaly though no there’s no screaming just a few wooops.
    allthegear
    Rachel {feels like she’s missing out on the tandem action}
    MartynS
    with a following wind I’ll be showing my ugly mug… got a few things to do in the morning but should make 10.30.
    NBT.. If I’m not there go, and I’ll catch you up!
    Sandwich
    I have to wuss out of this due to an infection. You’d all get fed up of waiting for me to return from behind trees and hedges!! The pootle would have become a dawdle. Have a good one.
    amodicumofgnar
    nbt – figure of 8 is my way of avoiding a ride up from taxal. The main change over the normal route is: from Elnor Lane Farm take dirt track / lane and then tarmac to Fernlee. Follow A5004 N for about a km. Turn right just after sharp bend onto cart track, follow down to railway line. Then either N and then W over dam followed by climb to Oldfield and then S reversing the normal route to taxal. Down to ford climb out to A5004 and up past Shall Cross Hall Farm. Turn S at road and follow through to Fernlee. This time take road down to Fernlee Dam and either continue S on railway line to Errwood Res dam, cross and rejoin the normal route. Alt once back at Fernlee Dam repeat section back to Oldhall and then N through wood and onward on normal route.
    White hall bridleway can be a bit wet at Whitehall and just before it drops back to A5004
    There’s also the tie youself in a knot approach of doing Ladder Hill bothways. At Elnor Lane Farm, go to Fernlee, then Fernlee Dam, reverse the normal route to Taxal. Infact just reverse the whole route to Whitehall. Then take the bridleway W to the A5004, head N for about 1.75km and then head W on cart track to railway line by Res. Head N to Errwood Dam and follow the normal route.
    sambob
    I presume you’re riding there oldagedpredator? If so are you going over Ladder hill or along the road?
    nbt
    singlespeedstu – Member
    It’s like riding witha chuffing monkey on the back of the bike
    “oOiiOOohh AAahha OOOhhOOOhhOOohhhHAAAhHAaah AAAAARRFGGGAHHHGGGG”
    Pook
    Crikey – 5 pages and we haven’t even done the ride yet.
    More energy is expelled in tippy tapping on a keyboard than riding bikes on pootles I’m sure.
    Anyone fancy doing the maths?
    STW server time
    + individuals’ laptop charge
    + lost work hours
    against energy spent on a ride….
    which is more?
    amodicumofgnar
    Sambob – Should be riding there, over ladder hill if faff doesnt get in the way.
    Bunnyhop
    I’m selling my 2.0 litre (hardly used) Lezyne smartpack.
    All the tools are unused,(comes with pump, multi tool, tyre levers, no kitchen sink though).
    bladder (totally unused),
    black,
    Only a few months old.
    Retailing at £31.49 atm. Will sell for £20.
    If anyone’s interested I can bring it along on the ride tomorrow.
    binners
    Be warned. My back brake decided to wave two fingers at me this week. I’ve just bought a bleed kit and will be shortening my front hose while I’m at it. Anyone familiar with my gibbon-esque mechanical ability will realise what a high risk strategy this is the night before a ride. So…. expect the ‘can anyone lend me a bike thread to be posted about 9.30 tonight
    Mind you, I’ve insisted on taking over driving duties from the Enigma in the morning, so we at least stand a chance of getting there some time this week
    Hora pictured behind the wheel yesterday
    nbt
    Bunnyhop – Member
    black,
    It’s 3 litre, not 2, and it’s retailing @ 34.99 at the moment
    Binners, we have spare bikes, but you’ll need to ride from NBT towers
    binners
    I should be ok mate
    Hora’s coming round to help. So… me, Hora, a bleed kit, a hammer and some beer? What could possibly go wrong?
    nbt
    Are beer and kebabs involved?
    Is Paulypaul not playing out with us? OR the Hindes? not seen them for yonls
    lowey
    Apparently I’ve just been informed that i do have parental duties in the morning now. Great.
    Have fun guys. I will deffo make one of these rides soon!
    stanley
    Hey chaps, I’m going to risk it and come playing too.
    Will be first mtb ride since having bits removed from the knee 8 weeks ago. Can’t put much (any!) pressure through it, so might be walking at the back on some of the climbs! And descents too…….can’t risk crashing!!
    jamesgarbett
    I can’t make it unfortunately but was out earlier today north of Buxton and as said above there is a lot more rain damage than I expected
    singlespeedstu
    Right. The twinseated attentionchariot has been dug out from the bottom of the pile in the garage and fettled* So we’ll see you there tomorrow.
    *ridden up and down the street in a comedy style on my own then put back in the garage without doing anything to it.
    tollah
    Well that’s done it, just sharpening the carving knife and gone through my thumb :-0 so a ss it is then as I can’t change gear!
    NBT if SSStu is coming youd better order some extra attention in as he demands loads if it!*
    *even more than myself!
    sambob
    Okay, i would ride with you but it’s kind of the wrong direction, will see you all there 🙂
    nbt
    Ahh, yes, the fettling of bikes. I knew there was seomthing I had to do, we had a problem getting into granny ring last time we rode the tandem. Well, that’s tonight planned then!
    Stanley, you bringing Mrs Stanley or is she on emergency rescue standby for if (when) your knee goes?
The topic ‘PEAKS POOTLE: feb 19th, white peak’ is closed to new replies.
