Home Forums Bike Forum P7 rubber 0-ring for mounting
Viewing 5 posts - 1 through 5 (of 5 total)
  • P7 rubber 0-ring for mounting
  • doglover
    Does anybody what/where o-ring I need for securing a P7 torch to the handlebar ? I’ve already got a lockblock but would like to reduce the shakes even more. Thanks.
    doglover
    GW
    carlos
    Been using O-ring’s from inside a 40mm push fit plumbing connector, T/Y (depends how you look at it) junctions have 3 in them. I pinched mine from a plumber at work 🙂 yes he knows as wouldn’t want anybody to have a leak.
    On oversize bars they fit nice and tight with no wobble at all, if your on standard size bars maybe try a 32mm.
    so maybe a plumbers merchant. You should be able to just get the O-rings.
    Carl
    Vortexracing
    Pack of large o rings from B&Q £2.00 – ideal fit.
    doglover
    Thanks just what I needed to know, will check out my local plumbers store.
The topic ‘P7 rubber 0-ring for mounting’ is closed to new replies.
