Old Atco mower proj...
[Closed] Old Atco mower project.
27 Users
Offline  stevied
Share this post
Just picked up a 1960's B23 Atco as a little restoration project.
It's a good runner and cuts very well but is in need of some TLC.
Posted : 13/05/2018 8:52 pm
Offline  fadda
Share this post
9 minutes, and you haven't posted the 'before' pics?
Shame on you...
Posted : 13/05/2018 9:03 pm
Offline  stevied
Share this post
I've tried but the stupid f***ing mobile version is impossible to use..😨
Posted : 13/05/2018 9:06 pm
Offline  slackalice
Share this post
Quick! Before I start using google please! 😉
Posted : 13/05/2018 9:11 pm
Offline  stevied
Share this post
https://photos.app.goo.gl/eU8xir1Kb4CUClYx1
Posted : 13/05/2018 9:15 pm
Offline  fadda
Share this post
Is mower envy even a thing?
I don't even like cutting the grass, but I fancy a project like that one...
Posted : 13/05/2018 10:05 pm
Offline  hot_fiat
Share this post
Nice! I took on a 1930s atco. It was an absolute bastard thing with a Villiers 2 stroke. The cretinous heap would happily kick back off the handle and start itself in reverse, when it did run properly, you had to run after it as it was setup to do about 7mph.
Posted : 13/05/2018 10:10 pm
Offline  stevied
Share this post
As I couldn't post on mobile, here's a couple of pics:
As it runs well, the first job will be to strip as much of the casing as I can to sand-blast and re-paint. I'll then look to strip the engine to clean/paint then replace the controls/cables to get it up to scratch.
More to follow....slowly probably 😉
Posted : 14/05/2018 8:10 am
Offline  mcmoonter
Share this post
Laughing at hot_fiat.  When we first came here our lawns were in a poor state. My dad borrowed a big industrial mower from his work. It had sort of single wheel clutch to help it make a turn at the end of each cut. One wheel would lose drive and the other would whip your ten year old body off the ground to start the next cut. It may have had that clutch on each wheel to turn in either direction.  It also had a moss scarifier which we only tried once. A single pass of the tennis court sized lawn yielded enough moss to fill a skip.
Keep the pics coming OP
Posted : 14/05/2018 9:10 am
Online  singlespeedstu
Share this post
That takes me right back to my youth.
My first job was as a lawnmower mechanic.
Those old cast iron engines sound so nice when you get them ticking over really slow with just the occasional ching from the centrifugal clutch.
Posted : 14/05/2018 9:54 am
Offline  stevied
Share this post
It does sound lovely, like what I imagine England used to sound like on a Sunday morning all those years ago 🙂
So, should I keep it green? Part of me wants to keep it original the other part wants to make it different...
Posted : 14/05/2018 1:51 pm
Offline  fadda
Share this post
If it were me, I'd definitely keep it as original as possible.
I am a nostalgic old Hector, though...
Posted : 14/05/2018 2:03 pm
Offline  hot_fiat
Share this post
We seem to be a nation obsessed with putting everything in formaldehyde, from buildings to bits of useless 70s tat (especially mechanical stuff).
Cobblers to that! Steampunk it. Fit an arduodino-based injection system and roots blower then take it racing!
Posted : 14/05/2018 2:18 pm
Offline  prawny
Share this post
Keep it green, you could probably make a few quid on it. My dad had a couple of Atcos (he was a poper lawn nut) and they cost a fortune, but when he got rid of them they fetched a decent amount too.
Posted : 14/05/2018 2:26 pm
Offline  mugsys_m8
Share this post
Think there's a good James May Dismantler episode on an old lawnmower on you tube.
Posted : 14/05/2018 2:27 pm
Offline  stevied
Share this post
Started stripping her down last night 🙂
Have got the basic covers off, air filter, exhaust etc so starting the shot-blasting process:
Luckily I have access to a shot-blaster, polishing kit etc at work so that will help with keeping it cheap as I can do most of the work myself 🙂
Posted : 15/05/2018 9:03 am
Offline  stevied
Share this post
Pull-start cover cleaned and given a light polish:
Posted : 15/05/2018 11:22 am
Offline  fadda
Share this post
This is very promising - please carry on, stevie!
Posted : 15/05/2018 11:58 am
Offline  CountZero
Share this post
Needs James May voice-over!
Posted : 15/05/2018 12:12 pm
Offline  CountZero
Share this post
I’ve got ever-increasing numbers of cowslips appearing on my ‘lawn’, plus a lot of moss, gives me a good excuse not to mow it. It’s basically just two small squares either side of a path, I just use shears to trim the longer bits.
Posted : 15/05/2018 12:16 pm
Offline  stevied
Share this post
A bit more stripping tonight..
Posted : 15/05/2018 8:30 pm
Offline  stevied
Share this post
Posted : 16/05/2018 8:07 am
Offline  concept2
Share this post
Great project...
there is a guy on the forum below who knows the answer to any mower related question.  I think he may have had a business in the past.. I did something similar and had some help..
https://www.oldlawnmowerclub.co.uk/
Posted : 16/05/2018 8:44 pm
Offline  slackalice
Share this post
Why can't I see any photo's? All I have is a grey/white no entry symbol. Shame, as I'd love to follow your very cool project OP 😃
Posted : 16/05/2018 8:49 pm
Offline  stevied
Share this post
Cylinder bead-blasted and 1st coat of paint:
Posted : 17/05/2018 1:44 pm
Offline  somafunk
Share this post
no pics showing here either?,
Posted : 17/05/2018 2:49 pm
Offline  stevied
Share this post
weird, I can see them. Trying to use google pics...copying the address, pasting in the box etc..
Can anyone else see them?
Posted : 17/05/2018 2:53 pm
Offline  Rockhopper
Share this post
No, i can't
Posted : 17/05/2018 3:22 pm
Offline  stevied
Share this post
Let's try Imgur:
Start:
Some bead-blasting:
Polished pull-start cover:
More stripping:
Painted cylinder:
Posted : 17/05/2018 3:36 pm
Offline  maxtorque
Share this post
I have to say i'm not a fan of excessive resto jobs!  Leave the patina, but make it mechanically A1
Posted : 17/05/2018 4:26 pm
Offline  slackalice
Share this post
Nice! 😃  Imgur works!
Thanks
Posted : 17/05/2018 7:20 pm
Offline  fadda
Share this post
Yay!  Hooray for imgur!
Loving it, to be honest, I'm impressed and jealous in equal measure....
Posted : 17/05/2018 9:16 pm
Offline  stevied
Share this post
I'm not going to worry too much about dents and stuff so it will maintain some of it's battle scars.
Glad you can see the pics now, will continue to use imgur 🙂
Posted : 18/05/2018 1:35 pm
Share this post
You need to clean all the paint of the edge of the cylinder blades then grind the bottom blade flat and adjust it so it'll cut newspaper as you turn the cylinder by hand.👍🏻
Posted : 18/05/2018 2:09 pm
Offline  stevied
Share this post
We've got a cylinder grinding attachment for the cylindrical grinders here at work so will touch up the cylinder then lap the bottom blade 🙂
Replaced the old blade height adjusters with some new, stainless ones.
Posted : 18/05/2018 2:26 pm
Offline  v8ninety
Share this post
Ooh! I acquired an old atco mower too. It’s a bit of a shed (patina, yes definitely patina) and not quite as lovely or collectible as yours, but it’s put some good work in, and the kids love it👍🏼
https://imgur.com/a/J01edmo
Posted : 18/05/2018 5:56 pm
Offline  slackalice
Share this post
I am liking that! 😎
Posted : 18/05/2018 9:57 pm
Offline  stevied
Share this post
Looks like a beast v8 😎
Posted : 19/05/2018 9:50 am
Offline  grey
Share this post
I've a old Suffolk Punch to renovate as a project.
I really should get round to starting it.
Posted : 19/05/2018 6:36 pm
Offline  v8ninety
Share this post
It is! It has an (optimistic) 12hp on tap! 😱
Posted : 19/05/2018 8:38 pm
Share this post
If I owned that lawnmower I would just cover it in Chrome plating...the whole thing
Posted : 19/05/2018 9:25 pm
Offline  timber
Share this post
Similar to above, as your blasting and polishing, I'd just go with that as your finish but keeping the blade frame red.
Posted : 19/05/2018 9:56 pm
Offline  stevied
Share this post
It'll need painting to protect the metalwork.
Got the bearing plates done overt the weekend:
Posted : 21/05/2018 8:51 am
Offline  stevied
Share this post
Bit of ultrasonic washing and a light bead blast:
Before:
After:
Posted : 21/05/2018 12:11 pm
Offline  stevied
Share this post
Main chassis nearly stripped. Just need to get the clutch assembly off:
Posted : 22/05/2018 11:17 am
Offline  stevied
Share this post
Managed to throw some paint over the engine. Have stripped/re-blacked all of the bolts & nuts etc.
Starting to look better now.
I know it's not the right colour but I had some HT paint in the shed.
Posted : 23/05/2018 8:51 am
Offline  fadda
Share this post
You're cracking on with this - keep the pics coming!
Posted : 23/05/2018 9:35 am
Offline  mcmoonter
Share this post
Thread of the week, keep the pics coming
Posted : 23/05/2018 10:19 am
Offline  stevied
Share this post
Cheers guys, will update as I go 🙂
Posted : 23/05/2018 12:09 pm
Offline  stevied
Share this post
Got the main frame ready to paint. Gave the rear roller a good going over with the orbital sander too, came up quite well:
Posted : 24/05/2018 1:20 pm
Offline  jerseychaz
Share this post
I picked up an Allen Scythe late last year, a few bits and pieces and it runs - just about, I think the timing needs tweaking but on a Villiers 25C two-stroke that's a black art and a half! I'll post pics next time it's out of the shed
Posted : 24/05/2018 2:47 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
