Home Forums Bike Forum Oil on brake pads – can they be rescued?
Viewing 13 posts - 1 through 13 (of 13 total)
  • Oil on brake pads – can they be rescued?
  • jamesgarbett
    Or fit only for bin?
    uplink
    I’d scrub them with some meths & then take a blow torch to them
    If they work – all good
    if not – bin ’em
    ivnickkate
    Back in the day, we cleaned car brake pads with clothes soap powder boiled in cooking pots, seemed to work okay then.
    goog
    put them in some tinfoil with a clove of garlic and a nob of butter and cook for 20 minutes on gas mark 4
    bonesetter
    baking will work…
    use of a blow torch is advisable for domestic harmony though 😉
    icedmind
    use alcohol(cleaning alcohol here im talking about) or any form of degreaser wif wet and dry paper and sand sown the pad surface
    if oil is completely soaked through the pad then u ll need to change them
    dmjb4
    Bake them in the oven. Wait until you are doing a roast or something and give them a couple of hours. Has worked for me – mineral oil on julie pads.
    nostoc
    isopropyl alcohol
    snakebite
    oven for an hour then a quick rub on a brick…sorted.
    bullandbladder
    Spray with WD40 and set fire to em.
    doof_doof
    It might just be me, but people seem to make way too much fuss about spilling fluid on pads. i’ve managed to do it a couple of times, and after dragging the brakes down a couple of mild downhills, the brakes are back to full power.
    omaknees
    Anyone tried sticking them in a dishwasher?
    I haven’t but seems reasonable. Just a thought.
    B.A.Nana
    I was told to put them in a metal tray or something similar, put some meths in and set fire to them. I’ve done this just recently but haven’t fitted the reclaimed flammin pads yet so can’t say whether it worked. 🙂
The topic ‘Oil on brake pads – can they be rescued?’ is closed to new replies.
