Home Forums Chat Forum Not putting the heating on – how’s it going…?
Viewing 40 posts - 1,601 through 1,640 (of 2,012 total)
  • Not putting the heating on – how’s it going…?
  • fossy
    No heating here, not had any on for months. That said we did notice the radiators had come on in the hot spell we had a couple of months ago – the motorised valve had stopped working, and left the circuit open for heat and hot water. Fortunately, only had to replace the motor and not the whole unit – £25.
    Cloths drying done on a couple of racks and a dehumidifier.
    the-muffin-man
    I had the hood down on the soft-top on the way into work this morning – bit fresh, but refreshing also! 🙂
    On the heating cost front my DD with Shell has come down from £215/month to £151.00/month. Two bed semi with two people living in it.
    Our heating is turned off so it won’t kick in unless it drops to 5 degrees.
    Kryton57
    Not needed here in the sunny South east, having been only as low as 19 degrees during the recent lull in temps.
    Neverthe ess, Octopus want to put my monthly payment up from £226 (dual) to £238 because “…despite falling prices our calculations show you will have a shortfall for Winter 23/24…”  WTAF!
    the-muffin-man
    Are you in credit by a few hundred at this point of the year? If not they will raise your DD.
    fossy
    We’ve finally got Scottish Power’s algorithm to reduce ours to £230 a month and we’re about £300 in credit. that’s after withdrawing £400 last summer, and another £400 in Spring as we were overpaying but the DD algorithm wouldn’t let us reduce it – overpaying by nearly £100 per month.  No smart meter but I send readings in every month.
    Jolsa
    Thing I did notice recently is the combi boiler had taken itself off eco mode, and was firing up to keep a bit of water hot ready for use. Think it’s done this before when we’ve had a brief power cut/dip. Anyway, soon pressed that Eco button once I heard the boiler come to life with no demand from me!
    iainc
    as per earlier posts, our Hive pops the heating on temperature dependent, regardless of the time of year.  It was rarely on here in west of Scotland through May and June, but has been on a few times in the past month.  Quite nice to wander into a warm ensuite for morning shower !
    We are on a standard Scottish Power tariff and pay a bit over £300 a month and as usual are a couple of months in credit at the moment which will reduce as we come into winter.  Having just last week picked up an EV, which will be charged at home probs once a week, at a cost of £27 for a charge, I’ll be intrigued to see how long it takes SP to clock it and increase the monthly DD  !
    Kryton57
    Yes, about £300.
    the-muffin-man
    Weird then – have you started growing any medicinal plants in the attic!? 🙂
    1
    scotroutes
    Our non-smart thermostat does the same. Mrs S commented the other day that the radiators were on in the morning. It had been down to about 3C overnight so no real surprise.
    trail_rat
    House hasn’t got cold enough despite outside being grim and cold thanks to the significant insulation done over winter. Mostly the last 10% of the insulation detailing that usually gets missed.
    matt_outandabout
    Login to the website, they have a nice graphical representation of what your usage and account balance will be for the next 12 months. The longer you have been with them, the more accurate that is.
    We are deliberately £700+ in credit and it is forecast to be +£400 by March still. This is because we have been on a silly cheap fixed rate for the last two years which runs out first week of September and we know that we are at least +40% on costs – but buy having headroom in money there we can delay upping our direct debit just yet.
    Fingers crossed for some slightly cheaper rates soon….
    One of the best things we ever did was install an outside temperature sensor as well as internal thermostat. It is not a ‘smart’ thermostat per-se, but it has ‘learned’ how the outside temperature affects indoors, and with a fully modulating boiler it just reduces use.
    We also turn off the heating at the boiler until we really do need it.
    julians
    There is prediction by cornwall insight that gas and elec prices will drop by 5% on oct 1st. I read an article on it yesterday (cant remember where)
    sweepy
    I now come down every morning to a **** oven, radiators on since 05:00 and woodburning stove on. Then she’ll spend half the day moaning that people dont take the climate emergency seriously.
    matt_outandabout
    Indeed, Money Saving Expert site is suggesting the same. I think we will drop onto a variable for a few weeks and see how it goes.
    Of course the energy companies are all happy with the (huge) increases in standing charges which will not come down if energy costs come down.
    We stayed in a 3 year old house on holiday. It was properly airtight, properly insulated, short pipe runs, air source heat pump and solar panels (no battery or MVHR). It was amazing how warm it was and how much we needed to keep windows ajar as we are used to a cooler building. The owner said that they have been amazed how cheap the three cottages have been to run – and are looking to rebuild their own home to a similar standard.
    I do wonder how long we will hold onto ‘old’ houses that are inefficient. Even our 1970’s house is a real issue – some narrow cavities, existing wider cavity ‘has’ insulation in (a mm or two thick of dusty white foam patches inside), floors which all need insulating from below etc.
    Last week has renewed my intention to either self build or buy a newer build property soon.
    nickc
    So, Octopus are offering a fixed deal for a year (with exit penalties) with prices of about 6% lower than cap. Anyone jumped on it?
    I’m considering it.
    2
    the-muffin-man
    While they are building shoddy hen boxes crammed onto featureless estates I’ll hang on to my 1920s house thanks! 🙂
    fossy
    Colleagues moaning the office was ‘cold’ this morning. They need to cycle to work and generate some heat !
    jeffl
    We’ve moved into a new build, which is significantly more airtight and better insulated than our old Victorian semi.
    We’ve spent £110 this first month, which is exactly the same as the old house, but the bulk of it is for electricity and £9.60 is for gas, which is basically hot water as the heating hasn’t been on. Frustratingly of that £9.60, £9.15 is the standing charge for the pleasure of having a mains gas connection.
    Will be interesting this winter as we were easily spending £300 month on gas and electricity last winter.
    But the house is noticeably warmer and we keep having to crack the windows open even with all the trickle vents open.
    monkeycmonkeydo
    @trail-rat what was the last 10% of detailing?
    trail_rat
    well the last 10% of my install will likely be different to yours – but minimising cold bridging, draft exclusion, insulating the coombs of the eaves  while retaining required airflow. the scuttery bits that take for ever that people never get round to (me included) i found those made more difference than the bulk of the insulating i did sooon after i moved in 10 years ago.
    matt_outandabout
    We have been offered the same. Renewal is 21st September, so I plan on watching the next few weeks before I sign up. Besides which, they will transfer me off my uber cheap deal from the day we sign up – so longer I can push it the more savings.
    Still have our upstairs windows open, they have been since early April. Heating may go on in October if it’s cool one.
    simondbarnes
    I’ve had to start paying for electricity again as the £400 government payment has now run out. Bit of a bummer as I haven’t got a job at the moment. Hopefully it’ll be a mild autumn and I won’t have to turn the heating on.
    Sandwich
    Hugo sent out an email earlier this week suggesting this was not a good deal as the cap is due to fall again at the next revision.
    Text of the email below.
    A lot of users have been asking why Hugo is still not showing new tariffs under the TARIFFS section in the app.
    Whilst wholesale energy prices have fallen significantly from their winter highs, the options are still limited, and fixed deals are mainly only offered to existing customers.
    Of those suppliers offering fixed deals for 12 months, the deals are between 1% or less cheaper than the current energy price cap. The concern for us at Hugo is that these now come with a £150 to £200 exit fee.
    From 1st October, all the signs are that the new Energy Price Cap will be lowered to 6.7p per kWh for gas and 27.2p per kWh for electricity. With standing charges staying the same.
    This represents a 5% reduction in energy costs as opposed to the 1% being offered.  The £150 -£200 exit fee makes this, in our opinion, not worth taking the fix until the 1st October Energy Price Cap announcement is made.  Then, fixed deals will likely be offered on or below the October price cap rate.
    In effect, fixing now could mean you £300 worse off (including the exit fees).  But the security and peace of mind of a fixed rate for 12 months at the current price cap could bring peace of mind. However, the chances of the current government increasing the Energy Price Cap during the cost of living crisis and an election cycle remain very low, in our opinion.
    So, we think it is worth holding on until the 1st of October price cap announcement before fixing. Fixing before winter for 12 months is on balance, though, a sensible thing to do. As wholesale rates are more volatile during winter as opposed to summer. We will keep you posted throughout August/September on this position.
    bennyboy1
    Been quite pleased that our June gas + elec bill was £87, July has been £79.
    DD was set at £130/month but energy provider has allowed me to now reduce it to £98/month, ~£230 in credit currently.
    1930’s semi with double glazing, combi boiler. Just me and my wife and we’re pretty eco minded but use the heating when we need it.
    james-rennie
    This is possibly a question for a fresh thread…   but how I do I go about finding out what needs insulating on my 1974 house?    Are there reputable experts out there than can come round and tell me where my heat is going, what insulation methods are suitable etc?
    blackhat
    Engage one of those bods who do an EPC rating on houses when they are put up for sale?
    singletrackmind
    Been paying £40pcm after the government loan over last xmas.
    Still £222 in credit so hopefully can keep it at that level for the rest of the year.
    Chew
    Ideally you’d want a PAS2030/5 survey completing. Not cheap, but it will give you a specific list of items to increase the energy efficiency of your home.
    Alternatively you can look up your EPC rating here:
    https://www.gov.uk/find-energy-certificate
    This will give you some generic items to implement to improve the rating
    julians
    Its easy enough to look for yourself – get up in the loft and see what insulation is in place – measure how thick it is, or if any is there at all. If the loft is boarded out then either lift a board to see if there is any at all, or just measure the height of the gap between ceiling of the room below and the loft.
    Current recommendation is for 27cm of insulation in the roof, I would guess that its likely you have 10cm right now .
    While you’re in the loft , go to the edge of the building and shine a torch in the wall cavity and see if you can see any existing cavity wall insulation.
    on a cold day go round the house feeling for drafts, and fix them as you.
    Presume you windows are double glazed? if not , then swapping to double glazing could be worthwhile, but not cheap.
    simondbarnes
    Cavities? Luxury!
    thisisnotaspoon
    What Julians said.
    Start by just going round and blocking up any drafts that shouldn’t be there (e.g holes drilled by BT/sky for their cables and not finished neatly), adjust windows so they seal properly, fit draft excluders to doors if needed, renew the rubber/foam seal on exterior doors, replace extractor fan exterior louvres with ones with flaps that close, put foam draft excluder strips around the loft hatch, etc. Those will make the biggest difference.
    Loft can be DIY’d, Step 1, top up the existing insulation along the joists, so if you have 6″ joist and 50mm insulation, add another 100mm between each one. Then add a layer of 30cm rockwool over that running perpendicular. It’s a faffy job and the biggest source of heat loss so IMO not worth just doing the minimum, may as well go as deep as you can.
    Cavity walls need a contractor to do it, depends on the condition of your house and location. There are internet horror stories of damp worth less houses after insulation, but most seem to have been damp beforehand, if the cavity is already damp then insulation will be a disaster, if the house is nice and dry, pointing is in good condition, etc then it should be fine (as long as you’re not in an exposed location). Ours came with a survey of itmes to fix at some point e.g. none of our windows have trickle vents which will probably never get done.
    tenacious_doug
    Yup, I did yesterday. 6% less than current, cap forecast to drop 5% but that still means the fix is cheaper than the cap.
    The advice above only seems relevant to the other fixes on the market which are more in the region of 1% below. 6 below is pretty attractive for certainty if nothing else.
    zntrx
    A couple of questions for the masses.
    We’re in the very lucky position that we fixed our gas/electricity for 2 years in August 2021. Our fixed deal is just about to come to and end and we’re looking at around a 75% price hike. I guess we can’t complain too much as most others have been stuck with this for a long time.
    We’re now rolling onto Eonnext’s variable tariff. In Glasgow for Electricity this is 29.67p/kWh and 61.67p standing charge. I’ve searched a few suppliers and they all have standing charges of around 60p. Our current standing charge is 12.39p.
    I can understand the standing charge increasing with inflation but this is somewhat more. Any idea what the rise in standing charge is paying for (I’m assuming this is actually us paying back the energy loans from last year or is it something else)?
    According to ofgen the standing charge is capped at 53p. Why then is the standing charge in the Glasgow area above the price cap?
    zntrx
    With a bit more googling I’ve answered my own questions via MSE.
    molgrips
    Ours still isn’t on, naturally, but with the realisation that type 21 rads are basically the same size as type 11 I have started to upgrade them. I’ve done 2 today and have one more. I may do others later in the year. As well as slightly improving the efficiency I want to be in a position to install a heat pump when the gas boiler eventually fails. Apparently with the grant they can cost the same for the unit, other required upgrades notwithstanding.
    Adding about 1.2kW of nominal heat output
    oceanskipper
    Mine’s been on several time already. Just for 30 mins or so to take the edge off. I’m feeling the cold at the moment clearly. 🙄
    simondbarnes
    Windows still open here and wearing shorts. Heating a long way off yet.
    the-muffin-man
    Mines been on to make sure it all still works! Don’t leave it till a cold day or your plumber could be busy! 🙂
