Home Forums Bike Forum New to 29er so please humour me!
Viewing 11 posts - 1 through 11 (of 11 total)
  • New to 29er so please humour me!
  • 1
    bikerevivesheffield
    Old bike:
    Aeris am160 with 170mm fork
    27.5
    New bike:
    Aeris am9 with 150 or 160mm fork
    29
    The old setup/bar/seat height were dialled perfectly for me. Do I mimic this as closely as possible or is it more “suck it and see” on bar height?
    5
    susepic
    Set it up close to old bike and then adjust from there
    1
    dickie
    Your a bit late, we’re on 36ers now;
    The True 36: 36″ MTB
    DickBarton
    I found the previous height stuff wasn’t right going from an Aeris 120 LT (27.5) to an Aether 9 (29) – both same travel at rear but the 9 was 150mm.forks rather than 140mm – however, I have a higher front end on the 9 and it has been fantastic.
    Saddle height also appears to be slightly higher – I do t mean amount of post showing I mean actual saddle height from ground is slightly higher.
    I’m not feeling as pitched forward as I was and I’m finding it far comfier on descents (although I’m still needing to up my descending ability).
    I last tried a 29er in 2018 and it was absolutely awful, really slow in the right twisty stuff and cornering felt like it took an age. Pleasantly impressed with the Aether 9 as it feels much quicker in the turns and despite needing to use a slightly easier gear on the climbs, it seems to move over everything with more ease.
    Sorry, bit of a story there!
    DickBarton
    Oh and if you don’t want to run a water bottle cage on your bike, would you sell me the adapter please? When I asked previously, I got offered a 3d printed one but I’m not keen on £18 asking price…so hoping someone gets a new Bird and doesn’t want the bottle cage adapter and I can get it for cheaper than that!
    bikerevivesheffield
    Lol about the cage. I’ll have a look if I can fit one in somehow first
    DickBarton
    The adapter realigns the position of the cage so it sits a bit further down the frame and is slightly flatter.
    If you have no luck and don’t want the adapter, please give me a shout, as I’d be very keen on it, ta.
    1
    bikerevivesheffield
    I know what the adapter does as use it on the am160
    1
    bikerevivesheffield
    I’ll let you know
    Assuming I’ve got the right bikes – not huge differences. Bigger stack on the new bike, which I presume you can sort with less spacers/less bar rise – or you might like it?
    Reach only 6mm difference and ETT the same
    Geometry Geeks
    bikerevivesheffield
    @DickBarton the fidlock bottle fits well so will be using the mount sorry
