Home Forums Bike Forum New Nicolai Helius AFR.
Viewing 14 posts - 1 through 14 (of 14 total)
  • New Nicolai Helius AFR.
  • the_lecht_rocks
    FR / DH capable frameset to 'replace' the venerable FR from what we can gather…..
    160 – 200mm rear travel and front mech fitment possible.
    more info here :
    http://forums.mtbr.com/showthread.php?t=529492&page=2
    I_Ache
    How do you fit a front mech on that its gusseted?
    tails
    would you have more than one ring at the front on a DH freeride bike, i wouldn't. In that instance whats the little nob for then.
    the_lecht_rocks
    the nob's for the front mech fitment i believe although looking at it, i don't see how it'd fit ?
    geetee1972
    If you look carefully at the stub behind the seat tube, you can see a small black dot. My guess is that this is a small threaded hole, into which you screw in an optional tube over which you can mount a front mech.
    nickc
    Would probably be right given Nicolais preference for doing things complicated when there a perfectly simple solution…
    Looks like a Helius, probably rides like one…A bit un-involved
    I_Ache
    I suppose there could be some kind of e type adaptor that bolts into the two holes behind the nob and the one at the top. Cant see what else they would be there for the frame would fill up with water if these were left open.
    the_lecht_rocks
    i_ache – the holes at the rear of the ST are bearing preloaders for the pivot bearings – nicely engineered, eh 😀
    nickc – un-involved……?
    nickc
    Yeah, mine was. Lovely bike an' all, but you know? 6+ inches of travel, made everything just a bit, I dunno, easy? Just have to aim it at stuff, and away it goes, it's like being permanently on autopilot.
    I_Ache
    Sounds like you need to ride rougher trails
    the_lecht_rocks
    ah – yes – i see what you mean nickc.
    i live in NE Scotland and there's lots of proper rocks up here 😀
    nickc
    Yeah, after going to the Alps on steel hardtails for all those years, you could imagine my disappointment. 🙂
    Kirroughtree was so much more fun on my Chameleon.
    the_lecht_rocks
    trail centres are alwats more fun on hardtails….
    toothpick for a gunfight springs to mind 😀
    JonEdwards
    Totems and a Hammeredschit and it would make a great Megavalanche bike – especially the qualifier. Agree it's complete overkill for UK riding though.
The topic ‘New Nicolai Helius AFR.’ is closed to new replies.
