Thanks. What wheel size on your five and also do you need to modify the muckynutz- looks similar design to the mudhugger so won’t be at the right angle without some sort of adjustment
The Five is a 27.5er (?)
The muckynutz adjusts via a pivot point.
The Mucky Nutz rear mudguard can be used in two orientations.
Short – as an all-year-round shock guard
Long – for full-length protection, when it gets mudtastic
Each MugGuard is made in the UK using 100% recycled plastic and comes with re-useable VELCRO® fasteners, so you can attach it to your pride and joy with ease.
In short mode, it works mighty fine as an all-year-round guard, protecting your rear shock and magnificent calves against splatter and matter, thrown by the back wheel.
And when the weather turns to sh**, simply whip out and attach the extension for full-length protection.
Full sus or hardtail, the MugGuard works impeccably on both. And is compatible with 26″ to 29″ wheel diameters and tyres up to 3″ wide… possibly a tad more.
Using its innovative dial feature, tune the guard’s angle to achieve the desired clearance with your rear tyre.
Each arm has a rubber base, for maximum grip on your seat stays and to help protect your bike’s precious paintwork.
