Home Forums Chat Forum MP3 player – help with forcing music to play in a set order
Viewing 4 posts - 1 through 4 (of 4 total)
  • MP3 player – help with forcing music to play in a set order
  • rob-jackson
    I have a very cheap screenless mp3 player like a nano. How can i force it to play music in a specific order? Do i need to to edit each tag?
    Jamie
    Depends, do you know it it read from filenames or id3 tags?
    rob-jackson
    not sure – any way to check?
    Jamie
    Other than trial and error, I imagine not.
    You could put, for example, 3 files on it named 01-xxx, 02-xxx, 03-xxx. If they play in sequence, and not in the order tagged artist/track number would dictate they should play, then you know it’s going off actual filenames.
The topic ‘MP3 player – help with forcing music to play in a set order’ is closed to new replies.
