Home › Forums › Chat Forum › Mortgage trackworld
- This topic has 85 replies, 24 voices, and was last updated 8 years ago by Kamakazie.
Mortgage trackworld
thestabiliserFree Member
Yes Jools and consider the case where the smaller loans rate is tenthousandkerjillionzillion% too
nickjbFree MemberSeriously how can you not get that the daily interest on his big loan is lots more than the lower loan?
Its a bigger total, certainly, but he is paying off a fixed amount. When paying a fixed amount pay the one with the highest interest, the total is irrelevant.
Say you overpay by £500, if you pay if off the small loan then you that’s £500 less that you owe at 3.19%, if you pay it of the big loan then that’s £500 less you owe at 2.84%.
thestabiliserFree MemberNo it isn’t.
Your reducing the term of the mortgage and hence reducing the compound interest so the total amount is relevant.
joolsburgerFree MemberOK whatever. I really am bored now. He’s not paying off a fixed amount either, an overpayment changes the monthlies, it’s a mortgage not a fixed term loan.
thestabiliserFree Membera one off would change the monthlies, regular overpayments reduce the term
nickjbFree MemberYour reducing the term of the mortgage and hence reducing the compound interest so the total amount is relevant.
Are you now arguing with this guy?:
Get rid of the smaller loan and then work on the bigger one
thestabiliserFree MemberNo, in this specific instance footflaps was right, it makes sense to significantly shortern the term of the smaller mortgage and then repay more on the larger mortgage
you’d save 15K on the smaller one and presumably more than 5k on the remainder of the other loan – although I can’t find a calculator that’ll let me postpone the overpayments for 13 years to accurately find out.
(If you go on a 12 year mortgage on the then outstanding 72k you only save 3.5k but that assumes a monthly payment capitalto interest ration that would be starting the mortgage term from then rather than the capital to interest ratio you’d have after half the mortgage term which would be more favourable.)
but it’s certainly not as simple or clear cut as you seem to think.
KamakazieFull MemberIt really is as simple as overpay on the highest rate loan.
There is no other answer.No it isn’t.
Compound interest has the same affect on every pound whether there are 100 of them or 50.That aside, you do not typically reduce the term of a mortgage by overpaying. With most mortgages, overpayments count towards reducing the monthly payment (smaller capital, repaid at x% over your fixed xx year mortgage). The term will only be reduced when you re-mortgage / re-negotiate.
breatheeasyFree MemberThat aside, you do not typically reduce the term of a mortgage by overpaying. With most mortgages, overpayments count towards reducing the monthly payment (smaller capital, repaid at x% over your fixed xx year mortgage). The term will only be reduced when you re-mortgage / re-negotiate.
Sorry, thats just incorrect. You agree with the mortgage lender an amount you want to borrow, the rate and length to repay – that gives you a monthly figure. Regular overpayments don’t mean the monthly figuire is recalculated every month – you just stop paying the same fixed monthly fee earlier.
ampthillFull MemberThat’s true for a single repayment,, annually compounded one year loan, not a mortgage.
Of course. But the point I’m making is that the cost is a fixed % of a the loan. That is always true for the same length of loan at the same interest rate
I did some calculations on this a few years back trying to decide if we should push to pay off all or most of our mortgage. Its so blindingly obvious but but I had been deceived by all the mystic stuff about compound interest
Lets imagine that that you have £10,000 in cash now and a £10,00 mortgage that runs for another 10 years.
You can borrow at 5% or you can save at 5%. Unlikely but it makes a useful comparison.
You can either pay of the mortgage in full and have no money
Or you can put the money in a savings account at 5% and make the mortgage repayments from the savings account. The end result is the same after 10 years you have emptied the savings account, you have no money
But usually it cost more to borrow than you get from saving. This favours paying off the dept
But if the roof blows off and you need £5,000 for a new roof then you might end up borrowing at higher rate than the mortgage you paid off
KamakazieFull MemberSorry, thats just incorrect. You agree with the mortgage lender an amount you want to borrow, the rate and length to repay – that gives you a monthly figure. Regular overpayments don’t mean the monthly figuire is recalculated every month – you just stop paying the same fixed monthly fee earlier.
It’s certainly correct for most fixed term mortgages (including my own) which I’d assumed these were (possibly incorrectly) based on the phrasing of the question.
I didn’t say it was calculated monthly, it is usually recalculated yearly when you receive a yearly statement.thecaptainFree Memberif you have a 100k mortgage at 2% and 50k at 3%:
In one year, the interest is 3500 making the total debt 153.5k minus whatever you’ve agreed to pay over the year in regular monthly payments.
Take 10k off the 100k, and the total annual interest is 3300
Take 10k off the 50k, and the total annual interest is 3200In each case the total debt at the end of the year will be 143.3k or 143.2k respectively minus your regular repayments. It should be fairly obvious which one is preferrable.
(Yes, I’m assuming interest and principal recalculated annually once a year, the principle is the same in other cases but the sums are a bit more work.)
thestabiliserFree MemberAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGGHHHH
FFupsS just put the fuppin’ numbers in the fuppin’ calculator!
ampthillFull MemberWhy should we put the number in a calulator. We know the answer
If you want the numbers in a calculator then put them in a calculator
nickjbFree MemberFFupsS just put the fuppin’ numbers in the fuppin’ calculator!
Can you give an example set of numbers where you have two loans and it is better to pay off the lower interest rate first?
thestabiliserFree MemberYes the figures in the OP. Assuming they were two separate loans.
As conceded earlier in this specific instance Footflaps suggestion, in terms of paying off the two in totality then it PROBABLY makes sense to pay off the smaller first.
nickjbFree MemberYes the figures in the OP.
Huh?! So why do you write this which is stating the opposite:
DaveRamboFull Memberin terms of paying off the two in totality then it PROBABLY makes sense to pay off the smaller first.
If the OP has to pay both loans then he should look at the effect on the total he pays.
There’s no probably about it.
eightyeightFree MemberBest. Thread. Ever.
Not that I’m a mortgage expert, but the Chartered Accountant in me would say you always pay off the higher interest loan first. It’s on that basis that I never paid off my student loan quicker as any excess funds went to settling overdrafts / mortgages which attracted higher interest rates.
thecaptainFree MemberI’d be interested in seeing the calculations that supposedly show it’s best to pay down the lower rate loan first. My guess is that there’s some implicit assumption in there about future payments that isn’t relevant or appropriate (especially given that the OP states hs can overpay either loan).
thestabiliserFree MemberI’d be interested in seeing the calculations that supposedly show it’s best to pay down the lower rate loan first.
and yet not interested enough to type ‘overpayments calculator’ in to google.
joolsburgerFree MemberI feel I’ve sown a seed of disharmony here that is alien to the usual harmony enjoyed by the denizens of this forum and for that I am deeply apologetic.
Simply put someone needs to do the maths probably the OP as it’s ultimately all his fault.
I went to a mortgage overpayment calculator and put in his figures. I assumed a 20 year term on both mortgages and a £250PM overpayment for each until the loan is paid.
He saves 15,153 overpaying the larger loan with lower % off
He saves 11,623 overpaying the smaller loan with higher % offIf I’m not mistaken that means paying the larger balance first saves him more.
ampthillFull MemberSo The stabiliser
Joolsberger I assume you have made the same mistake
Based on TheStabilisers numbers
right!
over 25 years
£200/month would save you ~£15k on the smaller mortgage or ~£20k on the larger
in interestOK i have given i and repeated the calculation and you are not comparing like with like.
Yes the calculator gives the numbers you give. But:
You didn’t mention the extra 6 years of paying £200 a month!!!!!
You’ve saved an extra £5000 grand but spent an extra £14,000 to do so!!!!
Your numbers are over the life of the mortgages which are different time periods
thisisnotaspoonFree MemberWhat ampthill said.
If you have a fixed monthly pot to make repayments from, then at some point one or the other loan will be the only one left being paid, and at which point all your repayments switch to that.
Always pay off the higher interest rate first regardless of duration.
Extreme example, a credit card and a mortgage. If you paid off the mortgage first, yes the term would drop, but you’d owe a bazillion pounds on the CC by the end. If you pay off the CC in month 1 and put nothing in the mortgage, then the mortgage term increases by a month (and a bit due to compound interest, maybe a few months).
thecaptainFree MemberThestabiliser, I can certainly work out the correct answer myself, what I couldn’t confidently do without seeing your working is work out why you and some others were getting it wrong. Though it looks like my guess on that score was in fact correct.
thestabiliserFree MemberHSBC a and money saving expert both got it wrong too I suppose?
thecaptainFree MemberJust show your working. What site did you use, what numbers did you put in, and what answers did you get? Are you assuming the same total monthly payment (including overpayment) over the full length of the loans?
dooosukFree MemberAll you’ve said is this:
thestabiliser – Member
right!
over 25 years
in interestuse a mortgage overpayment calculator
ampthillFull MemberWell I’m glad we are all on the same page now
Did we all manage to get through without questioning each other parentage? Yes
Did I learn stuff? Yes
Did it stop me being bored? Yes
So the final question?
When the mortgage is finally paid off and the OP rolling in cash what will he spend the money on?
T5 camper conversion
Wood burning stove
A new bike. But If so what rim and tyre size will be the latest thing?
dooosukFree Memberdoosuk
But I did all the other bits. Read the thread
I have, but I’m right royally confused now. I thought you were disagreeing with thestabiliser.
ampthillFull MemberI was disagreeing but I assumed that “face palm” was agreement/could see where he had been mislead
Basically the bigger mortgage allows bigger savings as its bigger. But only as you pay for longer
In this case you over pay the high interest loan until it is paid off. Then you make over payments on the other. Presumably these over payments would be the full value of what you were paying on the first loan and the over payment
The maths is easy. Well easyish. What makes my head hurt is if you try and factor in say needing £15,000 in 9 years time to help the kids go to uni. Do you save separatly or over pay the mortgage. Over paying the mortgage looks better on paper but you don’t actually have the cash to hand over
ampthillFull MemberBut none of you have used the online calculators?
I did that is where i spotted the 6 year gap!
The topic ‘Mortgage trackworld’ is closed to new replies.
