Home Forums Bike Forum Microshift b-stop tab not mating with hanger stop tab??
Viewing 5 posts - 1 through 5 (of 5 total)
  • Microshift b-stop tab not mating with hanger stop tab??
  • baileyswalk
    Old Marin frame (1999) and the tab on the hanger looks a touch smaller than others but the microshift stop tab hing only just catches it and it won’t last long… Solutions? Will attach pic as I don’t think I described it v well.
    baileyswalk
    baileyswalk
    It looks like the stop tab on the derailleur isn’t bent round enough.
    1
    fenderextender
    It’s a ball-ache, but you can put the bolt in the wrong way up so that the wider head engages more of the tab.
    It’s not ideal because it makes it a PITA to set the b-tension, but you should only need to do that once in any case…?
    baileyswalk
    The b screw hits the tab on the derailleur OK. It’s the derailleur tab that only just connects with the nub on the hanger, pretty sure it will wear it through quite quick.
