Home Forums Bike Forum Marin pine mountain penknife bike- gravel wheels and tyre recommendations please
Viewing 8 posts - 1 through 8 (of 8 total)
  • Marin pine mountain penknife bike- gravel wheels and tyre recommendations please
  • timizere
    I have a steel Marin pine mountain, which currently has 27.5 x 3 tyres and a 130mm fork on it. I use it for bikepacking and some general local trail bashing. I’d like to make it faster for road/gravel for winter, so am planning the following changes-
    Hunt 29r xc wheel set, 26/28mm inner diameter
    Something like 2.1 mezcal tyres
    38 tooth chainring.
    It came rigid so I’ll put the rigid fork back on.
    Do we think these changes will make it a worthy of road/gravel or should I go even skinnier with the wheels and tyres? I’m a total road noob and have never owned a road/gravel bike.
    superstu
    If I remember that bike has quick release boost rear wheel which might limit wheel options. Is there definitely space for a 29r? I know my old whyte 905 wouldn’t.
    matt_outandabout
    All I can add is that Mezcals are fast off road. But there’s much faster on road tyres & treads. As ever, tyres are a set of compromises.
    I put Mezcals on my Marin Nail Trail and revel in the light weight and nippyness, but they area still quite wide and a tread. My 50mm (1.9?) Continental Terra Hardpack fly along in comparison on hard trails and roads.
    timizere
    yeh its boost qr both ends, but hunt supply hub adapters for qr so it shouldn’t be an issue. There’s a fair bit of clearance with chunky 3.0 tyres so I assume 29×2.3ish should be ok too.
    This is the kind of info I’m after. Hunt say of the XC wide rims;
    “Tyre size: Optimized for 2.2″ to 2.4″ tyres; work well with 2.0″ up to 2.6″ tyres.”
    Are there any recommended faster rolling tyres that would sit on those rims and have reasonable performance on road/gravel?
    It would be nice to have the 29×2 for winter road/gravel, be able to chuck on a set of 29×2.3 xc tyres for light trail bikepacking duties and have the 27.5×3 for when things get rougher.
    1
    steezysix
    A pair of 2.8 Schwalbe G-Ones will make road riding a lot nicer without having to buy a new wheel set. You’ll probably want a bigger chainring and smaller range cassette to put on as well!
    matt_outandabout
    There’s some cheap Teravails around at the moment
    https://advntr.cc/teravail-sparwood/
    timizere
    I’ve gone down this route, thanks for the recommendation! Mush less spendy than a new wheelset.
    PJay
    I’ve got a set of Continental Terra Hardpack tyres on my rigid Swift. They’re light & really good on tarmac and I’d imagine that they’d cope admirably on many non-sloppy gravel surfaces.
    They only come in 650bx50 or 700×50 (I do wish they’d do a 700×40) but I can’t think that you’d need anything wider if (like me) you’re mostly road based.
    https://www.conti-tyres.co.uk/gravel/terra-hardpack
