Home › Forums › Bike Forum › Lumicycle Halogen to LED conversion with piccies and a step by step guide.
- This topic has 372 replies, 66 voices, and was last updated 13 years ago by RustyMac.
BlackCatTechFree Member
Cree uprated the XPG after it had been released for a while. From what I can tell this is retrospective so any XPG can be run at 1.5A. Bloody difficult to cool though!
Just ordered some boards with a ‘hybrid’ 1.5A setup. The new Zetex chip still hasn’t made distribution so this is just my existing chip with an external transistor which should allow 1.5A operation. Hopefully a month…
One thing though, three XPGs run at 500mA will give out more light than one run at 1.5A – they lose efficiency as the input current rises. Costs increase though as you have to buy more LEDs and lenses…
troutFree MemberStuey
these are the newest R5s but what happened earlier this year was Cree upped the spec on their leds .
also backwards to earlier ones
the XPEs got rated @ 1000ma drive
and the XPGs went up to 1.5 amps
and a geeky guy with the right equipment has measured pretty much every led on the planet for lumens .
and also pushed them well past their rated limit .an XPG @ 1.5 amps puts out 460 lumens as opposed to 351 @ 1 amp .
and max`s out at 542 @ 2.6 amps then I guess it died .
compared to the XPG R2 which gave 252 lumens @ 1 amp
305 lumens @ 1.5 apms
and maxed out at 326 lumens @ 2 ampsso quite a big difference
BlackCatTechFree MemberThey don’t say what bin but Cree on their product info page give 493 lumens at 1.5A for the XPG.
The R2 bin aren’t much better than the old Seoul P4 based on that – they did something like 226 lumens at 1A.
Cree quote around 139 lumens for the highest bin cool white XPG at 350mA. Assuming 3.2V Vf this is 124 lm/W. At 1.5A I’d estimate the Vf would be 3.5V minimum so the efficiency drops to around 94 lm/W. Your 542lm at 2.6A is getting down below 60 lm/W so well past the point where the return doesn’t justify the increase.
You need to consider the size of the XPG also and think just how you are going to get all that heat away from such a small package. The extra work in thermal design as well as the more expensive 1.5A drivers can mean you are better off adding an extra LED and sticking at 1A.
stueyFree MemberThanks BlackcatTech / Troutie –
Soo …if I’m driving 6 XP-Gs at 1 amp(say 20watts) I’m going to get a a rise of 40deg with air flow over the heat sink (2C/W) –
Which drivers have thermal protection for when your stationary?
(I may just wait for troutie to bring out a 1000lm all in one? – waits for Luminous to hint 😉
troutFree MemberTrouties already got a 1100 lumen all in one had one for 18 months
and Wors on here has a prototype and been running it for a year .
It just needs some tweaking and a bit of weight loss but a fine light it is .
stueyFree MemberThat’s lovely – does the larger case manage heat better ?
‘Any more prototypes you want testing ? 😀
woody2000Full MemberIf anyone wants to give this a go, I’ve got some bits lying around:
2 x Lumi Halogen cans
1 x Lumi HID can
4ah NiMH Lumi bottle battery with twin leads
Fast charger for the above
2 x triple XRE boards
1 x quad XRE board (damaged one of the solder points, might be salvageable but I’m not sure)
Optics for all the above
1 x 3W driver, 1 x 5W driver
Odds and sods of wiring loomsI have soldered one of the triple XREs and the 5W driver, but they can obviously be de-soldered.
Mail in profile if interested – I’d rather sell it as a job lot TBH.
Gee-JayFree MemberI have a set of hope 2’s – about 3 years old so not the latest and lower on power. The battery has failed.
A new one from hope appears to be about £60 so not worth replacing but radio controlled shops appear to have similar (7.2v, 3300mAh) for £22.00 ish. I would have to change the connector but thats do-able, anybody tried it or know if it would work.
Also has anybody upgraded the LED’s to anything more powerful?
Many thanks
LuminousFree MemberIn addition to the helmet light that I plan to offer this season, I will have a light which contains its battery.
Fully sealed, just a couple of mm larger than a Maxx D.
Bar mount, QR, etc.Frustratingly, I am still waiting for the Anodizer to finish them (should be the end of the week) before I build them up.
I intend update with info as both lights progress.
Ta.
LuminousFree Memberbut radio controlled shops appear to have similar (7.2v, 3300mAh) for £22.00 ish. I would have to change the connector but thats do-able, anybody tried it or know if it would work.
Be very careful with RC stuff. RDH used them, but it may be better to look elswhere for your batteries, imo.
If you’re wanting the full upgrade, then I’d suggest contacting Trout.
With a fairly well sorted workshop, and numerous conversions under his belt, hes the man to ask, imo.stueyFree MemberOn the other hand – some RC stuff uses proper balanced charging – to ensure even discharge and longer cell life- My £30 programmable B6 charger even has a temp probe that will shut down if cells get too hot.
mark381Free MemberHi, just wondering if anyone offers a kit, or fitting service to convert the halogen Lumicycle lights to LED. I have some which are probably nearly 10 years old, the battery died years ago and I’v been using 3s1p lipo’s (model aircraft ones with balancer to power them since. Due to it being only 11.1V i’ve lost some power so would probably need to purchase an appropriate battery in order to run LED’s. Any idea what cost I would be looking at? or would I be better off purchasing a new purpose made light?
pdwFree MemberI’m in the process of converting one of mine. Here’s what I’ve spent (all prices incl postage):
Triple XRE LEDs + optic from Cutter – £26
Driver from Black Cat – £6.50
Thermal paste, wire, switch and resistor from Maplin – £11.72You’ll also need a heatsink. I’m currently having some made and should have some spare which you can have for £7 delivered.
The new switch and resistor is optional, but gives two brightness levels.
If you need a new battery, try http://www.mtbbatteries.co.uk/ (forum member, I think he can provide them with Lumi compatible connectors)
daveatextremistsdotcoukFull MemberI’ve been at it as well…..
7 XPGs just managed to squeeze in with Ledil lenses. Baseplate is 8mm thick alu.
Battery pack is 8 Nokia mobile phone batteries from 7dayshop. The LEDs are run at below max power such that the can runs as warm as I dare run it. About 1200 Lumens.
mikey-simmoFree MemberTrout, I’m in when’s it avalible?
and as for that 7 up lumi halogen can, blimey, thats quite a bit of heat management required there. But seriously nice work.Curly68Free Membermark381 – Member
Hi, just wondering if anyone offers a kit, or fitting service to convert the halogen Lumicycle lights to LED.x2 please.
mark381Free MemberPDW & Dave, thanks for the responses, just looked at the cutter website and convinced me i’m an electronics numpty, as there were so many options. I understand that the lumicycle halogen cans are 33mm, so i need a triple XPE and optic to fit this size. Also if I go the LED route will I need to increase the battery size from the current 13.2V to 14.8V to optimise the output?
troutFree MemberMark
I am doing one for a stw forum member with a 20 mm triple led and make a small heatsink to go inside.
Might get on it this sunday I have a few drivers / led boards / and optics available just not a lot of time at the moment .for a triple you will be able to use your battery no problem .
stueyFree MemberHave you seen these guys triple with driver lux-rc -not cheap but interesting Whats the best optic solution for throw vs flood -25deg?
mark381Free MemberTrout, thanks for responding, what is the cost per can for the conversion? I currently have two Lumicycle halogen cans, one currently with a 12w spot and the other a 20w flood. As for the battery, I need a new one so either a 13.2v NimH,or 14.8v LiPo is possible, I have a multi charger capable of charging just about anything so would use whatever gives optimum performance. Dependent on cost for the conversion I may just bite the bullet and go for a new complete system.
Yes have been watching those from early days brill idea but a tad expensive .optic wise the best is the narrowest with XPEs for throw or XPGs for a floodier beam .
Mark
£50 ish as per woodys post so may not be all that cost efective
LaddersFree MemberHigh guys!
I’ve been reading this thread and meaning to have a go at this ever since the beginning of the year. Now the nights are drawing in 🙁 this is something I want to have a go at.
Am I thinking right that the parts you need are:
3 x XRE LED’s (from Cutter, nowhere in uk you can get them?)
1 x XRE mounting board (from Cutter)
1 x Optic for MR11 Kits (from Cutter)
1 x LED Driver (where can you get these from now?)
1 x Heatsink (where can you get these from now as well?)
I’m also going to have a go at the dimmable version so will get the switch from Maplins. I think my switches are worn out anyway as the sometimes don’t work.
Cheers for any help!
Dave
BlackCatTechFree MemberI will be listing more drivers once the ‘group order’ (see DIY light thread) is complete. However, I’m also hoping to get this released soon:
which assembles with the LEDs to give:
I’ve also just found that the HID lumicycle can is larger than the halogen so I’m looking at getting a heatsink made for that.
My feeling at the moment is that the halogen can doesn’t have enough metal to support cooling three LEDs at 1A. I’m thinking either 780mA or 830mA as the standard option for this with a 1A driver for the HID can which has more meat to it.
The above driver will come with heatsink, switch and power socket. I’m currently thinking something like £12 including P&P. I need to get stock of the heatsinks though before I start selling properly. I’m also considering buying some LEDs and optics in and selling as a complete package that will just drop in to the case. Not sure on price as I’ll have to work out prices and factor in the risk of being hit by customs charges.
pdwFree Member3 x XRE LED’s (from Cutter, nowhere in uk you can get them?)
No – you buy a pre-assembled board with the LEDs on it from Cutter.
I’ve got some: http://www.singletrackworld.com/forum/topic/fs-heatsinks-for-lumicycle-led-conversion
LoveTubsFree MemberNot sure if this required a new post, so forgive me for bumping this one.
I was reading through another light thread on MTBR regarding a guys light housing project getting back off the ground…looked good TBH…3 LED optic was suggested.
So, with two arrays (he had a unit with x2 20mm holes) of 3 XPE LEDs would they be connected in paralles, series or a combination or just series??
BlackCatTechFree MemberIt is better to connect in series but with that many LEDs there are other concerns. If you connect in parallel, unless the LEDs are perfectly matched the current won’t share exactly. Also, in parallel you would need a driver that can output twice the current – two perfect LEDs in parallel will split the current in half between them. Therefore, to drive each at say 1A you would need a 2A driver. This is the problem – unless they are identical one will get more current than the other and you either risk overloading it or you have to run them below their rated current to let this happen safely.
The problem with series connection is that the voltage adds up so six XPEs in series would be about 21V. This means you’d either need a 24V minimum battery or a boost driver which tend to be more expensive.
One option would be to use two drivers and run the two sets of three independently. You could then have different lenses on them for spot and flood and have independent control of the light levels of each.
mark381Free MemberBlackcat, I would be interested in a kit, would this work off my new 14.4v battery from Smudge?
stumpy01Full MemberMy feeling at the moment is that the halogen can doesn’t have enough metal to support cooling three LEDs at 1A. I’m thinking either 780mA or 830mA as the standard option for this with a 1A driver for the HID can which has more meat to it.
BCT – this sounds ideal. Preferably at 830mA! 🙂
LaddersFree MemberBlack Cat, I would be very interested in the kit as well, what sort of price would it be?
SmuzzyFree MemberMe too, be very interested I have twin halogen set gathering dust, it would be great to put them to use
foxyriderFree MemberI have tried emailing blackcat about the kit and no reply – I guess he’s busy?
VortexracingFull MemberBlackcat have you got any of those new drivers like in the piccie yet. and is so what amps are they running at?
The drivers i’m on about are the trimmed ones, your last ones that I used in the conversion when I started this thread off were a little tight.
BlackCatTechFree MemberSorry for not getting back to people, this week has been a little mad!
I’m currently building a batch of the lumicycle-specific drivers. I’m aiming to standardise at 770mA output but I could increase this up to 1A as the circuit is basically the same as my standard driver.
The main problem I’m having is getting heatsinks turned. I’ve managed to get a few done at work as foreigners but that doesn’t seem to be working out for more than a couple at a time.
The other issue is that the switch I was going to supply has gone on back order until December. I think I’ve found another one which the standard lumicycle boot will fit though.
The intention is to supply driver, heatsink, switch and DC power socket all wired up as a kit so you just need to supply LEDs and optic. At the moment I’m looking at an ‘ebay price’ of £12 per kit but that depends on supply of heatsinks, if I have to get them made out it may end up being more expensive.
If people can supply their own heatsinks and just want the driver then that would be £6 or £8 with switch and socket.
Off-ebay prices by negotiation, typically 10% off for singles. P&P £1 per order.
Only one thing – I’m off work next week and my test kit for the drivers is there. I’ve tried to rig something up for home but I’m not sure how well it will work. If I can’t properly test them here then it will be a week before they are ready.
PaulBFree MemberBlackCatTech
I would also be interested in the Lumi kit. Particularly if it had optics and LED’s in it, minimum of two sets, me and my son.
Medium optic to start with and then convert the other cans to narrow at a later stage with narrow for the helmet.
Paul.
foxyriderFree MemberBlackcat – If you had a std kit with optics – or a choice of say 2 or 3 kinds you could probably make a bit of a profit as you would be saving us the hassle of multiple orders and the risk of getting it wrong as most of us are plebs when it comes to the intricacies of LED, Lenses, Heat sinks, looms and drivers. I’d happily pay up to £40 for a kit if I could reselect my lumi cans? Anyway thats for all you have done so far and I’m in for a “kit” and of course there is no rush 🙂 Thanks BTW 🙂
stumpy01Full MemberThe other issue is that the switch I was going to supply has gone on back order until December. I think I’ve found another one which the standard lumicycle boot will fit though.
How about the Maplin switch?? Or is that pricier than something you can get hold of?
I used it for my first can conversion & it seems fine.
bruneepFull MemberI’ve also just found that the HID lumicycle can is larger than the halogen so I’m looking at getting a heatsink made for that.
I converted my HID thanks to Chucky/vortexracing.
NobeerinthefridgeFree MemberI’ve done this conversion about 6 months ago, brilliant light, really impressive.
Seems to have developed a wee fault though, when I turn the light on initially, it’s about half power, then after a while the thing blasts out light the way it should?!. This can be after 2 minutes or half an hour, and doesn’t seem to be linked to the heat of the unit either, any ideas any of you light guru’s?
mikey-simmoFree MemberGood work – I did suggest this to lumicycle about three years ago. Pillocks!
The topic ‘Lumicycle Halogen to LED conversion with piccies and a step by step guide.’ is closed to new replies.
