Home Forums Bike Forum low profile stem
Viewing 6 posts - 1 through 6 (of 6 total)
  • low profile stem
  • turbo1397
    I know there was a post recently regarding this( or similar).. problem i have got is i like quite a high bar height. with the setup i have the the top stem bolt isn’t actually clamping round the steerer tube..i was running a 60mm stem which ‘just’ clamped round, but been fettling and prefer a 70mm stem.. looking for one with the a lower profile so they both clamp.. 😕
    takisawa2
    It’s a Crank Brothers one (IIRC), that has a very low clamp height.
    turbo1397
    Great cheers. just found the correct term i was looking for.. im looking for a low stack height.. also found the posts! thanks
    njee20
    Surely a higher rise stem makes more sense? Ritchey and Bontrager do 17 degree ones.
    turbo1397
    i could probably take a 5mm spacer out and go for a stem with a bigger rise.. it semms that 70mm stems with a low stack height are rare..
    JoeG
    The stem with the lowest stack height that I am aware of is the Ragley Stubbing, but it looks like they don’t do a 70 mm one.
    I have an On-One Ultralight CNC stem and the stack height is only 35 mm. For comparison, a Ritchey stem that I have is 42 mm.
The topic ‘low profile stem’ is closed to new replies.
