We used to have a clunky metal sliding step ladder into the attic which the wife hated because it was always dropping dirt onto the carpet when it was opened regardless of how much you cleaned it and was difficult to put away as it covered half the available attic floor when stored. When I converted half the loft to an art studio I replaced those steps with a simple telescopic ladder that was light, easy to use and compact. Clearly this was wrong as the ladder is too steep and has no hand rail.
Any suggestions on how to build a set of steps, with a hand rail, that are light, compact, comfortable to stand on in bare feet and will fit?
The upstairs landing with the size of the hatchway shown. The hatchway is quite narrow to fit between the beams.
The hatch open with the current ‘too steep’ and painful to stand on ladder
The view from in the attic. You can see where the current ladder folds up to which ends before the blue painting. The two big beams of wood are what the old steps were fixed to and it used to slide down at 90 degrees to the current ladder meaning there was little room between the steps and the hatch when walking up them.
I would like some steps that go up the same direction as the new ladder but cannot find any commercial ones that are narrow enough to fit. Any suggestions or plans welcome.
