Home Forums Chat Forum Locking Wheel Nuts – Land Rover HELP
Viewing 14 posts - 1 through 14 (of 14 total)
  • Locking Wheel Nuts – Land Rover HELP
  • Killer
    So I have some locking wheel nuts on my Range Rover.
    The locking nut key snapped over the weekend and after some lengthy conversations with a number of Land rover dealers and internet (and ebay) searching i have come to the conclusion that i do not have anything anybody has seen before.
    The wheels are off a Range Rover Sport and the nuts are pictured below i hope.
    THe key has a B or possibly an 8 printed on the back of it. However, every type of land rover locking nut does not look anything like mine.
    I was hoping somebody on here could help with one of the following;
    a) DOes anybody know what type of key this is and where i coudl get a replacement?
    b) does anybody have a B key that looks like this that i coudl borrow to get all of mine off and through them away (beers available in reward)
    c) Suggest a way to get these nuts off the car? bearing in mind they have a spinning outside part?
    geoffj
    Reciprocating saw to split the outer and then a set of these
    http://www.amazon.co.uk/Irwin-Bolt-Grip-Remover-Expansion/dp/B000QW6K8I/ref=sr_1_1?ie=UTF8&s=diy&qid=1282674762&sr=8-1
    You may need to fabricate some sort of guard to prevent the wheels getting scratched in the process though.
    Good luck
    sobriety
    If you have access to a welder you could weld a nut onto it and undo it that way.
    scaredypants
    shove some blutack/PoP/summatelse in to take an impression & use it as a template to make a new key ?
    oily
    It's only the very outer ring that rotates, right?
    I've had success in the past by tapping a locking nut at an angle with a hammer and punch to work it loose.
    carlos
    HTH
    A) Could be McGuards – http://www.mcgard.com/AutomotiveProducts
    B) Very unlikely to find a match
    C) Take it to a reputable garage that sells tyres/exhauts etc.. and they should have a piece of kit similar to a bolt extractor. I got quoted 30 quid but it wrights off the locking nut, which is fubar anyway.
    Carl
    dalesboyz
    if you got a some one to drill a thread into the middle of the stud the put either a left hand thread bolt into or just a normal one once the bolt reaches the end of the taped hole you will be able to apply a lot more pressure and be able to undo the wheel then just replace the stud with a new one which should be the cheapished and most affective way along with causeing no damage to the wheel or your hud
    dalesboyz
    also i may also be able to get the a new key from work if you send me a picture of the key with some dimensions i will have a look it we stock them and if we dont i will send it to a brit tool to have a look at it
    (p.s i work for a massive company which wholesales all tools and fastners)
    carlos
    http://www.dynomec.co.uk/ is the sort of things some garages use
    Killer
    I'm more than happy to throw the set away afterwards.
    Welding is a little out of my experience to be honest and i want to remove all four so was relaly looking for the repeatable way.
    Dalesboy: would love to take you up on the offer, but the key has disintegrated hence the issue. happy to send what's left if you think you can help.
    I have no tap or die sets nevermind left hand thread ones.
    thanks anyway guys. still struggling i think
    user-removed
    I broke my key, went to my local Mr Clutch and they drilled out all the locking nuts. I supplied a replacement set and the whole job cost me £20. Bargain.
    Oh, and I bought the replacement set at a nearby autoshop for about £15.
    scraprider
    local land rover dealer, looks like a freelander 2 locking wheel nut / after market wheel nut key,seen loads like that , land rover tech.
    Barney_McGrew
    Had to do this to my sister in law's car a few weeks ago.
    We got a socket that was 'just' to tight to go over it and witha mash hammer forced it on over the locking nut. It cuts into the metal and then use a ratchet to take it off.
    The socket can split so better to have too many than not enough but I managed to get all 4 off using 2 sockets.
    Just don't miss when you're hammering it on 🙂
    martinxyz
    yep,just use an old socket that nearly fits on and hammer it on. before it is nearly unscrewed, waggle it to remove it.
    i have to admit i still nip up my mcguards this way after losing they tool as im too lazy to buy 4 plain bolts for the winter wheels.
The topic ‘Locking Wheel Nuts – Land Rover HELP’ is closed to new replies.
