Home Forums News Lezyne Shock Drive 400psi Shock Pump review
  • This topic has 10 replies, 10 voices, and was last updated 1 year ago by nickc.
Viewing 11 posts - 1 through 11 (of 11 total)
  • Lezyne Shock Drive 400psi Shock Pump review
  • stwhannah
    This Lezyne Shock Drive 400psi is very much a premium – and reassuringly chunky – affair. Capable of going all the way up to 400psi.
    By stwhannah
    Get the full story here:
    https://singletrackworld.com/wp-content/uploads/2023/09/lezyne-shock-drive-400psi-shock-pump/
    dc1988
    Does anyone do a shock pump with a decent grip for both hands? This looks like the handle is good but not the barrel. I tend to find shock pumps are a pain to use when you start getting near 300psi and you can’t get a good purchase on them
    zerocool
    I have one and it works great.
    Kramer
    I have to say that with the sensitivity of modern forks and shocks to set-up conditions, I much prefer the precision of a digital shock pump, and use a lifeline one.
    Getting consistent pressures with an analogue pump is nye on impossible IME.
    sharkattack
    Also a Lifeline digital user here. It’s the same one you can buy branded as Fox or Rock Shox for £100. I won’t go back to a clockwork gauge now.
    mashr
    dc1988
    Lezyne are particularly good at forgetting that people need to hold shock pumps. I had one* of their digital ones, but gave up after they both fell apart
    *two
    mrchrist
    Wtf are people pumping up to 400psi?
    bigyan
    Rear shock IFP. Some high pressure shock pumps (600psi) are also require a lot less force at normal shock pressures than a 300psi pump, so easier to use.
    rickon
    My one of these lasted a couple of years before the seal went. I suspect it was due to the way you’re forced to hold the pump them inflating, which is the grab the dial, and when pumping it then rocks against the shaft putting pressure on the seal.
    It was ok. It looks nice. But the basic ones you get with a fork are much nicer to use and last longer.
    zerocool
    Do people not just hold on to the shaft when they use the pump?
    nickc
    I use a Topeak one, the pocketshox and it’s very easy to get consistency with it despite it’s analogue dial. I think it’s probs more to do with build quality than read-out method. Perhaps the Lifeline pump is just well made?
