Home Forums Bike Forum in need of some puff
Viewing 7 posts - 1 through 7 (of 7 total)
  • in need of some puff
  • trickyhill
    Has anyone got a solution to using Hopes ‘little bleeder’ bleed kit without having to use a car tyre for the supply, its going to be a ball ache to do this, I was going to grab the spare out the boot until I found out it was a space saver, bummer!!!
    R
    Bicycle inner tube.
    TandemJeremy
    Just bleed conventionally without the kit
    trickyhill
    Was told by several people it was much cleaner and quicker, however they didnt mention the car tyre, I have now bought it so would like to use it to see how it lives up to all the recomendations!!! but I aint standing out by the car on the road with tools freezing by balls off……..god dam space saver tyres
    Phil_H
    Can’t you use your bike tyre or don’t you run schrader valves/tubes?
    trickyhill
    apparently a bike tyre does not have the volume to do it properly as it requires 20 psi+ at a constant rate, hence a bike tyre will initially supply enough but quickly go flat where as a car tyre has the pressure and volume to last the duration of the bleed process, might try it though to see what happens.
    schwimoid
    Bleed them without the kit, much easier.
The topic ‘in need of some puff’ is closed to new replies.
