I think this is an upgrade problem: I suspect the OP upgraded his version of GirlFriend to GirlFriendPlus 1.0, which is a Terminate and Stay Resident version of GirlFriend. He then discovered that GirlFriendPlus 1.0 expires within a year if you don’t upgrade to Fiancee 1.0. But soon after that, he had to upgrade to Wife 1.0, which is as well all know a “huge resource hog”. Hence the OPs problems its a resource allocation issue. It has has now taken up all of his bandwidth, so he can’t run anything else. One of the primary reasons that he upgraded to Wife 1.0 is that it came bundled with FreeSexPlus 1.0.
Well it turns out that the resource allocation module of Wife 1.0 often prohibits access to FreeSexPlus, particularly the new
Plug-Ins he wanted to try, again all those suggestions to try different ports may be causing the problem. On top of that, Wife 1.0 must be running on a well warmed-up system before he can do anything.
Wife 1.0 came bundled with MotherInLaw 1.0 which has an automatic pop-up feature that he can’t turn off. Some of you have suugested variations of installing Mistress 1.0, but if you try to run it without first uninstalling Wife 1.0, Wife 1.0 will delete MSMoney files before doing the uninstall itself. Then Mistress 1.0 won’t install anyway due to insufficient resources.
