Home › Forums › Bike Forum › Im still fuming..Is it just me or are rodies a breed apart…arrogant??
- This topic has 510 replies, 136 voices, and was last updated 12 years ago by specialknees.
convertFull Member
That said. 4 miles is a bit of a pain, so unless they were going at a pretty decent clip I’d expect them to let you pass at a side road or parking spot as a courtesy (as any other slow road users should: tractor, caravan etc)
For me this is the bit where the difference is made and something I always try to do and don’t feel comfortable riding with others who can’t show similar courtesy when a big queue is forming behind or even a single other road user is excessively inconvenienced.
specialkneesFree Member”Explain how they could have let you past safely”.
Many folk above already have.mrmoFree MemberI cant believe I kept my cool, probly wrong footed by the fact the rude one was female.
problem is by pulling in behind them, you are already causing a confrontation, it doesn’t matter what your manner is, I have had too many bad experiences with drivers and i suspect most cyclists have as well. The cyclists will be on guard, they will be expecting you to assault them, at least verbally.
Yes they could have pulled over to let you past, but so many variables as to whether they could have done so safely any earlier, lay-bys, steep hill, descents, gravel, etc,etc.
NobbyFull Memberits wide enough for two cars to pass but not two cars and a bike.
road just a bit too winding for me to pass safely.
not even a hint from the riders to form single file and let me pass.
Bearing in mind the first two points, how could the third be achieved?
There are c0cks on bikes, c0cks in cars, and even c0cks in pick up trucks that deliberately drive at you to force you off the road – that’s life, I’m afraid.
JunkyardFree MemberI think after 4 miles i would have expected the group to help me get past.
As a cyclist i tend to try and let cars past [ when i think it is safe and i will hog the lane if needed as
1. Its polite an makes them more likely to like cyclists
2. An irate driver behind you followed by another 10 is never a good idea
3. the prime directive is what is safest for me is what will be done..if that means locking you toughFWIW we have all had a car overtake a few of us then drive along next to you at the same speed after forcing their way ino the peleton [ often with only a few feet space to your side]…this is not safer for the cyclist so some wont do single file unless it is a long straight section
All these issues are solved by a bit of patience and courtesy from both sidesI thought inly 2 a breast was legal for cyclist am I wrong?
bullandbladderFree MemberJust common courtesy, innit? If I’m on a road, be it on fat or skinny tyres, I usually make a point of giving cars room to pass, mainly because I don’t like having an increasingly wound-up and frustrated motorist sat 2 feet behind me. The longer they have to wait, the more likely they are to take a chance at barging past and leaving you upside-down in a ditch.
The worst offenders seem to be the club-roadie types who appear to think their natty matching kit makes them immune – I got stuck behind a certain Midlands-based club wearing orange and blue yesterday – similar story to the OP, but without the confrontation – because I know how that would have turned out… 🙄
torsoinalakeFree Memberteamhurtmore +1
However, what surprises me is how many motorists haven’t worked out the simple combination of stick and pedal movements that make their car go faster. I generally cycle alone, but the vast majority of cars that make overtakes are chugging along next to me for far longer than I am comfortable with.
ooOOooFree Member4 miles? I can’t imagine a piece of road, even on the windiest country lanes, where with some give and take you couldn’t have got past. A decent tractor driver would have pulled over after far less.
But we won the tdf so I imagine roadies feel they can do what they want.
yunkiFree Memberit’s like the critical mass lot but with different haircuts..
some of you lot are so shallow..
courtesy costs nowt and it’s this sort of thing that really gives cycling a bad name.. never mind whether it’s technically legal or not..
specialkneesFree MemberJunkyard,
You have put it better than I ever could.I was patient and just needed a bit of assistance and cooperation from the group.
mrmoFree MemberI usually make a point of giving cars room to pass,
how, bare in mind the highway code guidance is quite clear on how the driver overtakes?
The only option is for the cyclists to pull over and get off the road if the road is that winding.
If you came up behind a couple of horses what would you do?
BruceWeeFree MemberCan someone explain to me how the group could have helped the car overtake? Or at least quote the bit where someone else has explained it?
binnersFull MemberRiding en masse 2 or 3 abreast with total disregard for whats stuck behind you?… Hmmmmmm…..
GrimyFree MemberWell if your going to start quoting the highway code to defend your troll point then it quite clearly states they were in the wrong in the section pasted below. We could rangel all day about the highway code and legalities, but point remains, roadies that hold up traffic for several miles are just bleeding inconsiderate of other road users. Even tractors pull in and let you pass if there’s a spot. Cycling like that just gives us a bad name.
66
You should
keep both hands on the handlebars except when signalling or changing gear
keep both feet on the pedals
never ride more than two abreast, and ride in single file on narrow or busy roads and when riding round bends
not ride close behind another vehicle
not carry anything which will affect your balance or may get tangled up with your wheels or chain
be considerate of other road users, particularly blind and partially sighted pedestrians. Let them know you are there when necessary, for example, by ringing your bell if you have one. It is recommended that a bell be fitteddave360Full Memberjust out of interest, what urgent mission where you on that meant that you couldn’t be slowed down for a couple of miles?
specialkneesFree MemberBruce wee,
You seem to looking for a fight?
Sorry, you got the wrong person.convertFull MemberCan someone explain to me how the group could have helped the car overtake?
By pulling over if opportunity arose. 4miles equals 12-15mins – I’d be feeling pretty uncomfortable if the same person was stuck behind me after that much time. Others clearly wouldn’t.
BruceWeeFree MemberBruce wee,
Sorry, you got the wrong person.Actually, I just want to know what you wanted them to do. Single file wouldn’t have helped so what was it they should have done to help you get past? Pulled off the road and stopped?
rocketmanFree MemberRoadies are not all bad.
The other day there was a well-fed group in Team Sky gear coming the other way while I was riding along the pavement on my DH bike.
I shouted WIG-GO! and they shouted WAN-KER!
Smiles all round happy days
convertFull MemberPulled off the road and stopped?
Yep, that’s what I’m happy enough to do every now and again( or at least a slow roll through a lay-by or passing place) on roads where backing up behind a bike is inevitable. 2-3mins max of stuck behind me and I have to stop every now and again seems like a reasonable compromise of inconvenience all around.
mrmoFree MemberEven tractors pull in and let you pass if there’s a spot.
If there is a spot, they got to a garage and pulled in.
job done.
still doesn’t help the OP overtake though and going by normal events, the car pulls into the middle of the group because it can’t complete the overtake, forcing riders to take evasive action. I have seen accidents due to this kind of stupid behaviour.
If you can overtake safely do so, if you can’t you wait. 10riders 2 abreast is about 20m, if they are in single file your looking at nearer 40m, on a narrow twisty road that is a long time to be on the wrong side of the road?
and i am interested to know where this happened i can’t think of many places where there are 4miles of bends where an overtake couldn’t be safely performed?
And people do seem very prone to getting stressed out by having to wait. so time perception gets a bit skewed.
HoratioHufnagelFree MemberIf you were in such a hurry why did you pull into the petrol station to
arguetalk to them.mjsmkeFull MemberCan someone explain to me how the group could have helped the car overtake? Or at least quote the bit where someone else has explained it?
They could have gone into 2 groups of single file allowing him to overtake in 2 stages as he was patiently waiting for 4 miles.
specialkneesFree Member”Pulled off the road and stopped”
Either of the above or simply go from three to two abreast would have helped.
Single file with a few gaps would have been even better.I suppose we are never going to all agree on this but if I was one of the cyclists I know I would have done something and Im sorry but three abreast is just asking for trouble in my book.
JoBFree Memberwould it been okay if they were on mountainbikes?
i’m guessing here, but even single-file those yard wide handlebars would be about as broad as two roadies
martinxyzFree MemberOh not another weekly road incident thread where the scenario gets analysed in more detail and from more angles than the ‘trial of the century’ with O.J freekin Simpson!
Get back to work,get out on yer bikes or hit another website before this turns into another 10 pager!
convertFull Memberand i am interested to know where this happened i can’t think of many places where there are 4miles of bends where an overtake couldn’t be safely performed?
If its a really busy day and there is a constant stream of cars coming the other way, I can think of loads of places.
specialkneesFree Member”If there is a spot, they got to a garage and pulled in”.
They passed at least three other places they could have done the same.mrmoFree MemberEither of the above or simply go from three to two abreast would have helped.
Single file with a few gaps would have been even better.Trust me it wouldn’t, it does cause accidents. cars and bikes in that sort of arrangement is never good.
You either overtake the whole group or you don’t.
specialkneesFree Member”If you were in such a hurry why did you pull into the petrol station to argue talk to them”.
I wasnt in a hurry, never said I was.
As I said I had cycle kit on and thought I would at least get an explaination, being part of the gang so to speak.gonefishinFree MemberSingle file with a few gaps would have been even better.
WHAT!!! There is no way in hell that I’d ever think that was a good idea either as a driver or a cyclist. Putting a car in the middle of a group of cyclists on the public road is never a good idea.
As a road user you have to expect that sometimes you will be held up by others. You do not own the road, you do not have special priviliges, you should not expect that other people should get out of your way (blue flashing lights excepted) although it is nice when they do.
BagstardFree MemberI rarely ride on the road, but in the instance above then yes, I would pull in at the side of the road to let the cars past as soon as I was able. It isn’t the TDF, a few seconds of their time could have saved the OP 12-15 minutes!
foxyriderFree MemberSome MTB’ers and some Roadies are – but the bast majority arn’t – that’s just their problem – don’t let them tar your view!
binnersFull MemberDoes anyone really care if a few roadies get run over though? Really? I mean, it’d just mean a few less overpaid, middle-aged marketing managers in the world, surely?
And how can that be a bad thing?
watsontonyFree MemberI HATE RODIES. not all off them just the ones that think thay are better than plp on mtb’s. all i say to em tho is watch this pop it up on rear wheel and thay soon put there heads down.
LuminousFree MemberPulled off the road and stopped
I did this once during the 50 miles I put in yesterday. It was not a problem for me and once the car had pasted I could happily continue along the country lane, without having a car behind me. This took all of a few seconds.
When walking along the foot path, if I become aware of someone walking faster than me or apporaching in the opposite direction, I will move to one side of the pavement and let them by.
mrmoFree MemberAs I said I had cycle kit on and thought I would at least get an explaination, being part of the gang so to speak.
As said earlier, the moment you pulled over, you are a threat, you are the idiot who is going to lamp someone. Or at least that is how you will be treated.
Yes it sounds like they could have pulled over, but depends on the group as to how easy it is to get everyone to realise a car is behind, where to get off the road etc.
I have driven devon lanes with a police car on blues behind me, no where for them to get past at that point but i know one spot, so aim for that, noticing after the event that i could have stopped elsewhere.
Lots of things may have been happening that you weren’t aware of.
watsontonyFree MemberDoes anyone really care if a few roadies get run over though? Really? I mean, it’d just mean a few less overpaid, middle-aged marketing managers in the world, surely?
+1,000,000
The topic ‘Im still fuming..Is it just me or are rodies a breed apart…arrogant??’ is closed to new replies.
