Home Forums Bike Forum How to measure BB size
Viewing 7 posts - 1 through 7 (of 7 total)
  • How to measure BB size
  • phutureproof
    I need a crankset and bottom bracket for my new (but old!) frame. Do I simple measure the width of the BB shell and that’s it?
    In the past, I’ve only ever replaced BBs, but this frame didn’t come with one so I’m not exactly sure.
    dufresneorama
    I think so. What frame and year is it? You can google it!
    richmtb
    Buy a Hollowtech II crankset and you get a one size fits all BB and a crankset in one easy purchase
    couldashouldawoulda
    richmtb – Member
    Good idea that – you’ll still need to measure it for spacers and that.
    Yes is the answer. Tape measure is fine. Probably 68 or 73mm. I’d guess 68 looking at it from here 😉
    ltheisinger
    richmtb – Member
    Not stricly true if its an 83mm BB?
    breatheeasy
    Assuming square taper bb, then should be obvious even with rough tape measuring that it’s either a 68 or 73mm bb shell. As to what axle length you’ll need for your cranks, that’s a different matter, though 113mm is standard for a mtb triple I think…
    phutureproof
    Thanks guys – good tip about the hollowtech 2! Its a 2004 (ish) blur.
The topic ‘How to measure BB size’ is closed to new replies.
