Home Forums Bike Forum how to make knee pads tighter?
Viewing 20 posts - 1 through 20 (of 20 total)
  • how to make knee pads tighter?
  • linedpaper
    Is it possible to bodge a knee pad to be slightly tighter? I have XS TLD KG5500 and they’re a little loose at the top, don’t think they’re supposed to be like that. Silicon strip maybe?
    ta11pau1
    Get bigger legs?
    Or, the elastic has gone (if they have any). Otherwise you could get someone who’s good at sewing to take them in.
    linedpaper
    Brand new! Smallest size there is. Bit of nifty sewing might work
    oldnpastit
    Suspenders?
    chakaping
    Stuff something underneath? I put a buff under one of my KG5400 where it rubs a bit, makes it tighter too.
    And ride more, so your legs get bigger.
    endomick
    Try a pound shop neoprene velcro knee brace thingy, under or over.
    greatbeardedone
    For the amount of protection, they’re a bit pricey.
    But the outer pad is very grippy.
    They’re made of a very stretchy spandex material, so you’re best to try a medium size first.
    The winter ‘sub-zero’ version is made from a less stretchy ‘roubaix’-like material, so go one size up if you plump for these.
    mcnultycop
    Squats?
    VanHalen
    Sew some velcro strap to the top?
    MSP
    A daily visit to greggs.
    mashr
    linedpaper
    Member
    Swap for pads that fit you?
    Alphabet
    Dick Tape
    kayak23
    My approach is leftfield, but I wear 3/4 undershorts, and I wear my G-form pads underneath them.
    Keeps them in place nicely. Plus I’ve not got pin legs anyway.
    bigyan
    Squats? Pies?
    You could cut and sew them, sew a dart in, sew on some elastic etc. I would want to do it so it does not crease.
    Blackflag
    This. Just buy some stretchy velcro straps and sew them on one side. Pull them across an fasten to tighten pads. Exactly like a knee support.
    cookeaa
    Isn’t this issue what These 661 “padlock” jobbies are intended for?
    cloudnine
    Another problem that can be solved by Cake.
    There’s no end to how amazing the stuff is.
    nwmlarge
    I bought new ones when mine started getting loose.
    trumpton
    sew in some velcro.
The topic ‘how to make knee pads tighter?’ is closed to new replies.
