Not what your asking by no need for a new outer when swapping to 10spd unless the current one is too short (doubtful). If you are happy swapping the cable for the existing 12spd that suggests the outer is fine.
Its the whole thing. chainring is 12spd, so I’d need to change that and that might affect chainline(or not, but I dont know), so i think it best to retain the 12spd, so i only need change the drivetrain(ring/cassette/chain
Is it a standard Pro 5 hub or an Ebike Pro 5?
I think I got the wheel from crc (or merlin, or somewhere, cant remember) but given its a standard alloy HG freehub, it is more likely to be the standard, and after looking on the Hope site under documents, there is a distinct difference between the Ebike body and standard 148 body, as well as different Ebike and standard freehubs
I’ll need to track down the info to know exactly which it is then go from there.
I was just suggesting it might be different given that the POE number is etched into the shell.
Etched onto the shell, just behind the driveside flange it says ‘max 108 points of engagement 6 pawls’, which kind of suggests you can fit 54 or 108, which itself is not the idea you get looking at 2 different hub shells and 2 different freehubs, unless of course theres a 54 or 108 in ebike flavors designed for the Eshell or the standard shell.
Might send Hope an email, but i think it best i try to get the info on which i bought. Be in my emails somewhere.
