Home Forums Bike Forum Hope rear- what do I need to convert to 10mm??
Viewing 15 posts - 1 through 15 (of 15 total)
  • Hope rear- what do I need to convert to 10mm??
  • hora
    End caps+a axle?
    Confused as didnt know a 10mm axle existed! My new frame turned up withou std drop outs grrrrr
    rob-jackson
    if evo just end caps, if old pro 2 axle and end caps
    greeble
    Pro2 evo just end caps
    Pro2 axle and end caps.
    Oh you can get 10mm axle or 10mm bolt up
    BTW what frame is it.
    hora
    New Meta5.
    10mm axle or 10mm bolt up?? Confused.
    RustyMac
    10mm will fit normal dropouts. Standard QR dropouts are 10mm.
    I am confused by you thinking this is non standard could they be 12mm?
    you have 2 options
    10mm bolt up
    This has an axle that is threaded at the ends and you screw in 2 10mm bolts to secure the wheel.
    10mm axle
    This has a hollow axle similar to a standard QR or 12mm maxle and you will need some kind of 10mm skewer to secure the wheel.
    TurnerGuy
    with or without std dropouts?
    std rear dropouts are 10mm, aren’t they?
    fivespot
    Stick to std. QR drop outs, It will save you time stripping it next week when you sell it 😀
    TurnerGuy
    I think bolt-up and thru axle will both work with QR dropouts.
    hora
    Ah panic over. They look bigger- measure 9/10mm across each dropout.
    Oops 🙂
    BadlyWiredDog
    Measure the drop-outs. As above a normal QR or a 10mm through bolt or through axle will fit in standard drop-outs. If the drop-out is wider, like 12mm, then it needs a 12mm axle. Do Meta 5s not have the option for either a 10mm or 12mm axle depending on which dropouts you fix?
    Like here: http://www.realcycles.com/brands/commencal_bikes.php
    BadlyWiredDog
    It’s okay, he can fix it by buying a new set of 12mm drop-outs then asking how to convert a Pro 2 to 12mm x 142… 😉
    greeble
    hora
    Bite me 😆 (but thanks guys)
    “Hora. Keeping Singletrack entertained since 2001”
The topic ‘Hope rear- what do I need to convert to 10mm??’ is closed to new replies.
