Home Forums Bike Forum Hope pro4 hub/ cassette question ?
Viewing 7 posts - 1 through 7 (of 7 total)
  • Hope pro4 hub/ cassette question ?
  • ton
    should there be a spacer between the cassette and freehub body on a pro4 hub ?
    at the back of the largest sprocket ?
    PJay
    On mine you need one unless you’re running an 11 speed road cassette (no idea about 12 speed).
    ton
    mine is 10 spd.
    is the spacer alloy ?
    2
    a11y
    Road cassette = no spacer.
    Any MTB cassette = YES spacer
    Edit – wrote that the wrong way round at first, sneaky edit.
    ton
    reeksy
    If you don’t have the spacer that they’re supposed to supply with the HG freehub then a bottom bracket spacer does the trick.
    damascus
    @ton, Yes, I’ve got a spacer on my 10 speed deore cassette on a hope pro 4 hub. I think it’s Ali.
