Singletrack's forums are sponsored by...
Forum sponsored by Saracen
Hope Pro II & S...
[Closed] Hope Pro II & Shimano 12 Speed Micro Spline
6 Users
Offline  beanoir
Share this post
Hey all,
I think I've got myself into a bit of a pickle with my bike build project.  Current set-up is a 26" Kona frame, 135mm width rear dropout and my wheels are built on Hope Pro II hubs (Non-EVO).  On a standard QR axle.
I've got a new XT M8100 cassette (and rear mech, shifter, chains etc) but I need to replace the free hub with a Shimano Microspline.  I believe that I can't fit the Microspline to the Pro II hub.  Is it true that I can convert my rear hub to a Pro II Evo with certain parts and then use the Shimano Micro Spline free hub and cassette ok..?
If the answers is yes, does anybody know the parts I need?
Posted : 15/04/2020 10:58 am
Online  PJay
Share this post
Does this help?
https://singletrackworld.com/forum/topic/converting-a-rear-hope-pro-2-to-evo-spec-possible/
Posted : 15/04/2020 11:14 am
Offline  carlos
Share this post
Yes, you can with a new axle and bearing set, maybe a different freehub spacer too. Assuming you'll reuse the end caps.
Stealth Advert - I'm 99.9% sure I have a brand new Hub229 axle in a spares box if your interested? I'll look later and if I have, £12 posted 1st class, PP Gift?
Posted : 15/04/2020 11:15 am
Offline  molgrips
Share this post
I wish I'd known that when I still had multiple sets of Hope Pro 2 hubs lying around.
Posted : 15/04/2020 11:19 am
Offline  beanoir
Share this post
@Carlos Yes, partly.  I read that thread last night.  What it didn't confirm was whether converting my hub using those parts would allow the new Microspline free hub to fit properly.
My other option might be to leave the hub as it is and use an MZ90 12S Sunrace cassette instead..
Posted : 15/04/2020 11:23 am
Offline  Brianblessed
Share this post
you will need a new axle (HUB229S), qr non drive side end spacer (HUB461N), 2mm axle spacer (HUB436) and a Pro 2 Evo Microspline freehub (not sure of part number for that). Do make sure you get the correct freehub as it comes with a specific end spacer, your original end spacers will not fit.
Effectively you will be converting your hub to a Pro 2 Evo Microspline.
Posted : 15/04/2020 11:34 am
Offline  beanoir
Share this post
@carlos i'll take the HUB229S please, it looks like i'll be needing it!  I couldn't send you a message for some reason, so not sure how to arrange.  Let me know tough 🙂
Posted : 15/04/2020 12:34 pm
Offline  beanoir
Share this post
@brianblessed super stuff, thats just what i needed.  thank you!
Offline  carlos
Share this post
@carlos i’ll take the HUB229S please, it looks like i’ll be needing it! I couldn’t send you a message for some reason, so not sure how to arrange. Let me know tough 🙂
I'll double check I've got one tonight, and then post up on this thread either way.
Posted : 15/04/2020 12:38 pm
Offline  andy5390
Share this post
FYI Messages are now working, just used it (for something else)
Posted : 15/04/2020 4:00 pm
Offline  beanoir
Share this post
@carlos email sent! 👍🏻
Posted : 15/04/2020 4:18 pm
Offline  beanoir
Share this post
Well I thought I'd just bring this to a conclusion.  With the help fo @carolos and with the parts list mentioned by @brianblessed I've now managed to convert my old Pro II rear hub to accept a new Shimano Microspline and 12s XT cassette.  Bike build finally finished and took it out for it's maiden voyage today, rode like a dream!
Posted : 27/04/2020 8:26 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
