Home Forums Bike Forum Help!!!!!!!! which SS cranks
Viewing 10 posts - 1 through 10 (of 10 total)
  • Help!!!!!!!! which SS cranks
  • I am at the end of my tether trying to decide what cranks to fit to my SS bike.
    I think it has to be Middleburn with a square taper BB but what do you guys think????????????????
    Stoner
    I was going to go exactly the same way, but in the end couldnt justify not using some 1997 XT square taper cranks that I already had with a nice salsa ring that are good for the job.
    The choice to make about middleburn though is whether to go for an uno (and limit youself to 32 and 34) or a carrier and fit your own ring giving you a 36 option which is what I really need for my rohloff on the 29er.
    When my XTs die, then it’s middleburn.
    will post a pic when picasaweb wakes up again.
    miketually
    I have Deore on my Inbred and Sugino XD on my Solitude. I can’t tell the difference.
    Hairychested
    I’ve used a Bonty ISIS chainset with a SKF bottom bracket for 2 years without issues. Cheap and chearful.
    Errrrrrrrrrm main reason for the change is the constant failure of ISIS bb’s
    I want to make it sexier too 🙂
    coffeeking
    XT S/taper and middleburn 34t up front iirc.
    JoeNation
    Middleburn Uno all the way if you want 32 or 34. Then if you decide to go geary you can just buy a new spider and rings and swap them out in five minutes.
    catfood
    I had the ss isis/square taper debate with myself a couple of years back, went Middleburn isis and the bb
    n
    m just lucky. I had a good read on the mtbr ss forum at the time (didn
    k
    ve not seen that complaint on here. Had a square taper bb on my old rigid for over 12 years and was still going strong when I decommisioned it.
    catfood
    Shonky/upshot of above post
    My isis over 2 years good
    mtbr ssrs reckoned sq taper bad due to tapers rounding off
    not seen that complaint here tho
    Hairychested
    ISIS BB’s by SKF aren’t sexy. They’re more like this girl you never fancied but slept with regardless only to discover she gave head like a pro. They work and give you peace of mind (which sadly cannot be said about FSA, RF or Truvativ).
    I have a set you can have for £40 posted. Remember – a drunk on the forum, that’s me, tells no lies 🙂
The topic ‘Help!!!!!!!! which SS cranks’ is closed to new replies.
