Home Forums Bike Forum HELP! Removing a stubborn RF Evolve XC crank
Viewing 9 posts - 1 through 9 (of 9 total)
  • HELP! Removing a stubborn RF Evolve XC crank
  • freeform5spot
    Maybe I am being a numpty but….
    I thought that to remove a RF crankset you have to effectoively tighten the main crank bolt to push the drive side off.
    If you unscreww the bolt all the way off there are 2 washers. Do I have to remove these before screwing it back in again?
    Help!
    I am about to resort to semtex….
    RudeBoy
    Hold on, what type of BB? Square taper, ISIS or external?
    I wouldn’t be tightening anything…
    freeform5spot
    external BB
    RudeBoy
    Ah, then maybe it needs another type cap/extraction bolt thing? The standard one screws into the axle, but the extractor one pushes it off. Don’t be tightening the standard fastening bolt up. I think you have to take that out, and use the extractor cap thing to get the crank arm off.
    freeform5spot
    Thats the bit I dont have then…
    b0ll0cks
    dobo
    there was a thread about this before, if i recall the older htii evolve cranks you need to undue the inner bolt and it self extracts (make sure the bigger outer cap is still on)
    if its the newer type you need a crank extractor
    freeform5spot
    newer type (hence being such a bell!)
    I guess its staying put this weekend then…
    RudeBoy
    Look on the bright side: you’ve just avoided destroying your cranks, by over-tightening them…
    freeform5spot
    you are right – cheers folks!
The topic ‘HELP! Removing a stubborn RF Evolve XC crank’ is closed to new replies.
