Home Forums Bike Forum Help please – brakes
Viewing 6 posts - 1 through 6 (of 6 total)
  • Help please – brakes
  • infidel
    Mrs Infidel has decided that she wants to come riding a bit so in a bid to make her bike (Kona Fire Mountain she has never really used and which sat outdoors for ages – before I met her I’d like to add!) a bit better I’ve replaced her Marzocchi MZ with a MX pro I had. Problem is that the MX has post mount and her brakes are IS with a 160mm rotor. I’ve looked on CRC and found a bracket to convert post mount to IS for a 170mm rotor but its out of stock….
    I’m thinking:
    a) a2z for an adaptor and buy a bigger rotor
    b) buy a post mount front brake
    Anyone got any ideas for a solution??!
    rockthreegozy
    What brakes on it just now?
    infidel
    currently – Shimano BR-M465 Mechanical Disc rear brakes with Avid FR-5 levers…
    infidel
    sorry – that should be BR-M465 front brake. Anyone know a solution?
    mysterymurdoch
    The M465 is a post mount brake anyway isn’t it? Won’t it work with a 160mm rotor without the adaptor? Have you tried?
    infidel
    I am an idiot. Mystery – you are a legend. Thank you indeed!!! Solution:
    look closer at caliper. Remove post to IS adaptor already there. Voila, a caliper that post mounts directly and a stupid me.
The topic ‘Help please – brakes’ is closed to new replies.
