Home Forums Chat Forum Help identifying bug / insect
Viewing 18 posts - 1 through 18 (of 18 total)
  • Help identifying bug / insect
  • doncorleoni
    Hi all, purchased a plant from IKEA the other day. Within a few days I noticed a load of tiny black round mites/aphids/weird things on the walls, hardly noticeable as so small.
    They seem to grip the walls incredibly well and don’t come off
    Very tiny, almost perfectly round. Less than a mm in diameter if not smaller
    Close up pic does not show any kind of head or legs – just a black ball. They leave a brown smudge when wiping off with tissue paper
    At first was not sure they were actually insects as could not see any visible movement..? But observing over a few hrs, they move about from place to place
    Google coming up blank – lots of similar mites / aphids but nothing that looks like my little friends
    Any ideas anyone? Will try attaching a pic below
    https://postimage.me/image/20241017-135347.UTAPoQ
    1
    maccruiskeen
    Its been nice knowing you
    2
    wheelsonfire1
    They’re young meatballs, let them do their thing and grow, later you can cut all their legs off and drop them in hot gravy!
    maccruiskeen
    More seriously though – them leaving a mark when you remove them doesn’t tally with your observation of them moving around – they’d leave marks everywhere if they were mobile. What you’re describing sounds like spider poop – which can be like hard, almost plastic-y dots that are very tenaciously stuck to the wall. Those would obviously not move about through. What do your observations consist of?
    Dibs on your bikes through
    bikesandboots
    I googled “insect dark round no legs”
    https://outdoors.stackexchange.com/questions/22707/what-is-this-tiny-round-shiny-black-bug-that-bites
    Whatever they are, I suggest you keep a few in a sealed ziploc bag in case anyone gets ill and they need to be analysed by a lab. Then incinerate the plant asap.
    1
    doncorleoni
    Ha cheers guys! Def not spider poo as have lots of that in conservatory… But that’s what I initially thought. I marked the position a few of the little buggers and left them for about an hour and they all moved to different places… So they are alive!
    Thanks for that link – did stumble upon that but was not too conclusive
    Plant is now outside and will be incinerated shortly
    Weirdly -they grip like mad, can’t easily brush them off and the few I have tried to remove have taken a little tiny bit of paint off the wall! Almost like they are latching onto to it.
    kormoran
    What sort of plant is it? And where was it grown?
    3
    joshvegas
    Imagine what they will do when they latch onto your face.
    doncorleoni
    Kormoran – good shout but no idea! I have emailed IKEA. It’s the one on the right in this link
    https://www.ikea.com/gb/en/p/succulent-potted-plant-with-pot-succulent-white-30546377/
    @joshvegas
    ! Ha ha yes this is what I am mildly concerned about. Think I managed to get rid of most of them now (must have been about 20/30 of the little buggers)
    maccruiskeen
    I rescind my dibs on your bikes.
    CountZero
    This is where facehuggers come from!
    timba
    Spider Mite eggs? Difficult to tell from the photo; red spider mites? https://content.ces.ncsu.edu/media/images/soredmt2.jpg
    hightensionline
    Was also going to say spider mite eggs – as above – as they look familiar.
    Funnily enough, they arrived on a (gifted*) IKEA plant and spread like wildfire to neighbouring plants. Wasn’t fun!
    *No, it couldn’t play the trombone or type the works of Shakespeare on a typewriter.
    doncorleoni
    Timba / hightension… Interesting thanks… Weird thing is though I don’t think the eggs will have the ability to move on their own? Unless they are being moved about to drive me crazy! I marked about 5 of the buggers with a pencil dot and after leaving them for an hour or so, they all moved about 30cm away towards the window.
    Got a few caught in a test tube so will see if I can find someone with a microscope! My pest controller mate is a bit flummoxed also. Maybe they are baby face huggers after all.
    Maccruiskeen – you sure you still want to rescind that offer 😉 ha
    joshvegas
    To be fair a nukeproof should be still after the obvious solution is carried oug.
    And if it doesn’t you probably have them on the trade description act
    mulacs
    IMG_0231
    https://images.app.goo.gl/ZKeMc48YWXQeGw9w9
    standards are slipping …
    maccruiskeen
    Maccruiskeen – you sure you still want to rescind that offer ? ha
    And risk further contamination? No thanks – you can keep your weird Porton Down escapees to yourself!
    CountZero
    Sure they’re not tardigrades? They’re almost indestructible! This one’s playing a sad tune just in case they’re it’s relatives…
