Got a DHX Air shock I'm having trouble with.
Seems to hold air pressure okay, but it's to be leaking maybe 2cc or so of oil from the main seal onto the stanchion every time I ride it.
I ignored it for a couple of months thinking it might be just bedding in, but starting to get concerned now that it is the damper leaking oil into the air chamber or something. Amount leaking certainly hasn't slowed down! Damper does still seem to be working at the moment.
Is it even worth opening these things up to take a look or should I just send it back (or is it normal for them to lose a bit of oil every ride?)
