Home Forums Bike Forum headset cup removal
Viewing 12 posts - 1 through 12 (of 12 total)
  • headset cup removal
  • timwillows
    How easy to remove these without any special tools? What do I need, a big hammer and a stick?
    kevonakona
    pretty much. remember to apply a little pressure (tapping) around the cup as opposed to try and smash it out in one go
    Captain-Pugwash
    I use a flat bladed screwdriver and a rubber mallet. If you’re not happy with that a packet of biscuits and a trip to you LBS..
    jfeb
    Yep. I use an old seatpost and a hammer.
    Captain-Pugwash
    I forgot to say a flat bladed screwdriver on the inside of the steerer tube so it sits on the headset cup then give it a tap with the mallet.
    timwillows
    OK, enthused enough to give it a go.
    whytetrash
    Top tip get a foot long bit of copper pipe 28mm? the fatter stuff anyway saw 2 slits in one end (divide circle in 4) if viewed end on, flare them out slightly works well as pressure spreads evenly….hope that makes sense?
    bakey
    Exactly as whytetrash says – the softer copper will do much less damage than a screwy.
    Stick and mallet works well too…
    bonesetter
    Hitting metal against maetal will produce this
    and this
    charliemort
    would a bit of curtain pole work?
    MrCrushrider
    just buy the proper tool, cost about £8 off ebay and saves loads of hassle. its false economy bodging it, you wont be able to use/sell the headset again, plus you have it for future jobs
    bonesetter
    One of these.
    Free if you know a plumber
The topic ‘headset cup removal’ is closed to new replies.
