Home Forums Bike Forum Giant Trance- 140mm to 150mm or straight to 160mm
Viewing 13 posts - 41 through 53 (of 53 total)
  • Giant Trance- 140mm to 150mm or straight to 160mm
  • hora
    Check all your pressures first- the easiest and cheapest is to check who/what the forks were set up for on the previous owner. If the previous owner was 20kg lighter than you or didn’t have a clue..
    richwales
    Riser bars are the thing to try. What’s the rise on the ones on there? There seems a larger diff between saddle height and bar height compared to your other bikes.
    renton
    I’ve got a set of race face atlas 30mm rise coming to try out.
    etsxteam
    I’ve built a 27.5 Trance Advanced up with Pike’s set at 150mm very impressed so far also got a couple of spacers under the stem
    renton
    What size and how tall are you bUd. Post some pics up.
    etsxteam
    It’s a small I’m just under 5′ 8″ bit worried at first with the sizing but got a Giant dropper on it with layback lots of standover clearance ! rode it about 6 times now and very impressed.
    Not sure how to post pictures on here ! let me know and I will try
    renton
    So Ive changed the saddle from he crap Giant contact one to my default charge spoon and that seems to have helped a bit !!
    renton
    Very Very nice mate !!
    martinxyz
    How tall are you,Renton?
    sten1
    140mm max travel, on a trance and feels a bit crappy past 130 if you ask me.
    billyboy
    Sorry if someone has already done this……….I didn’t read the whole thread, but……….
    In your first pictures the front of the saddle looked to be angled down a little bit at the front. That is going to push your weight more onto the bars.
    In your last pictures the new saddle looks to be angled up more at the front. That is going to stop your weight being angled down onto the bars.
    Maybe it was just the angle of the seat? Put it up more at the front!
    renton
    Martin. I am 6 foot 1 and a bit. Shorter legs but longer torso.
    Sten… The new trance is designed and fitted with 140mm forks as standard. The trance sx which is same frame as mine comes with 160mm as standard.
    Billy boy. You are right. The nose is down on the original giant saddle as that’s how I could get it comfy. I’ve swapped it out for a new charge spoon and set it perfectly level.
    Will see how it goes tomorrow.
The topic ‘Giant Trance- 140mm to 150mm or straight to 160mm’ is closed to new replies.
