Home Forums News Fresh Goods Friday 667 – The Holey Decking Edition
Viewing 13 posts - 1 through 13 (of 13 total)
  • Fresh Goods Friday 667 – The Holey Decking Edition
  • charliedontsurf
    Happy August Bank Holiday people! We hope you’re doing something nice and that the weather plays ball.
    By charliedontsurf
    Get the full story here:
    tthew
    If that tyre insert is open cell foam, does it not soak up a lot of sealant?
    Rubber_Buccaneer
    This
    The foam is made of open cells which can retain their own air pressure and releases the air held within the foam cells once the tyre starts to lose air
    Makes no sense to me, maybe something lost in translation?
    jamesfifield
    From the Vittoria website: “The foam is made of open cells . . . and it is covered with a tough waterproof skin which prevents cuts and any absorption of sealant”.
    1
    tthew
    Hmm, sounds like BS to me then.
    5
    stevie750
    don’t see it being as cheap as this dirt bag
    https://www.ikea.com/gb/en/p/frakta-carrier-bag-large-blue-17228340/
    1
    prettygreenparrot
    Waterproof to IP-67 rating (“dust and brief immersion in water”).
    Is this enough for day to day mtb use? My bikes have been in enough streams and ‘immersive’ rain that I wonder.
    alpineharry
    Surprised there’s this many comments with no correction of ‘Northumbria’ to Northumberland
    1
    zerocool
    @Stevie750 – combine it with one of these and you have a sturdy bag that helps separate kit/helmet from shoes.
    https://www.ikea.com/gb/en/p/droena-box-black-30219281/
    chipps
    IP-67 –
    First digit: 6 – Dust Tight
    Second digit: 7 – Protection against immersion (up to 1 metre for 30 minutes)
    Which is one up from “Protection against heavy seas, or powerful jets of water” and one less than “Protection against complete, continuous submersion in water”
    dangeourbrain
    Why would there be? Northumberland is in Northumbria so if they’re going to Northumberland they must also be going to Northumbria – unless they started there obviously.
    b33k34
    The Vyron MDS V.3 dispenses with a rechargeable battery, instead there’s a CR2 lithium battery
    That seems a very odd decision – so now both shifter and post use single use batteries that will frequently end up in landfill. Neither of those sizes are (AFAIK) available in NiMh or Li-ion rechargeable versions either.
    Seems a step backward and would put me off owning (CR2’s aren’t something you’d find in a corner shop or up a mountain either)
    robertajobb
    CR2 batteries. £10 for a pack of 2 at Argos.  Or £8 from Bezosazon.
    As seen in many cameras.
    (Lithium rechargeable ones are available- just not in Wilko’s or B+M, so you have to Internet shop around)
