Home Forums News Fresh Goods Friday 563 – Bank Holiday Treats
Viewing 19 posts - 1 through 19 (of 19 total)
  • Fresh Goods Friday 563 – Bank Holiday Treats
  • singletrackandi
    The sun is shining, the birds are tweeting, the bees are buzzing, and it’s the weekend! If you’ve failed to make plans for this summery treat of an Au …
    By singletrackandi
    Get the full story here:
    endomick
    Sonder dial dropper routing is dumb.
    matt_outandabout
    It raise my eyebrow too – however I guess it goes under BB and then up? Not sure if this is better/worse for routing, other than it surely will fill the frame with more water?
    What makes a saddle gravel-specific?
    matt_outandabout
    Marketing makes it gravel specific.
    teethgrinder
    Only available in 29er, our test set are laced to i9 Hydra hubs and come in at a ‘kitchen-scale-confirmed’ weight of 1,668g 9901g rear, 667g front), with valves and tape.
    That’s a heavy wheel!
    snotrag
    Loads of hardtails use the same method for dropper routing. On-one Scandal is the same (and more than similar in many other ways to the Sonder! Same factory, similar tubing, different geo?) .
    fenboy
    i confirm the saddle is very gravel comfortable. the tape while also gravel comfortable… don’t get it wet as it takes a week to dry……
    singletrackross
    @teethgrinder – thanks for pointing that out! (now fixed) I can confirm that the wheel does not weigh nearly 10kg, and is actually a very respectable 901g!
    Dats wot i fawt
    whatyadoinsucka
    1,668g (901g rear, 667g front) i don’t have an a-level in maths but that doesnt seem right.
    devash
    That saddle’s just what I need to complement my gravel-specific socks and gravel-specific energy bars.
    brakestoomuch
    Congratulations, Amanda. Group test of trophy cabinets incoming. 🙂
    desperatebicycle
    I’m gonna get myself into the dropper lever business. Markup on those bastids must be immense!
    tuboflard
    Went looking for “map below”. Left disappointed.
    amandawishart
    @tuboflard I’ve disappointed enough people in my life, so I don’t want you on that list! Map added 🙂
    tuboflard
    Thanks! 👍
    shugglez
    Know what would make a gravel bike more comfortable to ride?
    Suspension and bigger tyres, maybe add some knobs on them and a flat handlebar while you’re at it!
    Wait…
    redsnail
    Well done Amanda. 😀
The topic ‘Fresh Goods Friday 563 – Bank Holiday Treats’ is closed to new replies.
