Mark,
I’ve been running tracloc and then twinloc since 2006.
Its like a clutch pedal on a car.. its there, its a thing, but you just use it. It doesn’t take any thought.
We have some guides that remove the remotes and run stuff fully open all the time.
I’ve liked the traction mode on every length travel 3 mode bike I’ve had (pretty long list).
Lock out for relatively smooth climbs, traction mode (reduced travel rear, added compression to fork) for tech climbs and any descending where I’m not balls to the wall. Fully open if stuff is getting steep or super fast. I’m in traction mode way more than in descend mode.
I can’t actually think of a Squamish descent trail that I would be stuck in open mode for. Maybe p’nuts/19th but everything else has at least some point where I’m going to be pedalling even a short section and clicking into traction (simply because its there as an option)
Scott have constantly improved their integrated cabling but yes there are cables, but it doesn’t bother me in the slightest. I absolutely appreciate that can be a thing for people though.
If you remove the remote setup, you may as well switch the forks remote top cap for a lever top cap. Direct swap, I do it pretty often when swapping forks. Rear shock, totally fine to just run it open and set your sag that way, but if you’re going to be using the bike as a 150mm North Shore ‘crusher’ then I’d consider a Float DPX2.. but the Nude with its Evol can is plenty of shock as is.
