Home Forums News Fillmore Valve – did the worst bit of bike tech just get better?
Viewing 40 posts - 1 through 40 (of 87 total)
  • Fillmore Valve – did the worst bit of bike tech just get better?
  • stwhannah
    It seems pretty universally agreed in the mountain bike world that Presta valves are horrible. Fiddly little bits of tech that leak, clog, spontaneous …
    By stwhannah
    Get the full story here:
    Joe
    Been using presta valves for 25 years. Not had any problems. Call me a luddite.
    Storer76
    I’d be interested to see how nicely these play with Cushcore or other inserts that sit right up against the rim…
    Yak
    How much??
    Presta valve cores cost about 50p if you buy 10 at a go. But yeah, presta is rubbish for clogging but at 2 cores per year, it’s a 9year payback for the upgrade… Hmmmmm.
    stwhannah
    @Storer76 the FAQ section says ‘the poppet pushes against the CushCore when you release pressure, so it takes additional force on the cap to let the air out of the tires.’
    trail_rat
    Yeah that.
    scotroutes
    You wot?
    kelvin
    Weird… are you people not using tubeless sealant? Because all the issues this seeks to address happen regularly for me.
    sharkattack
    Yeah, Presta was fine until tubeless sealant came along.
    Don’t worry about the price. Cheap copies coming from Alibaba in 3..2..1..
    molgrips
    This is brilliant. Can I buy some?
    Presta valves work ok but there are slight issues. Nothing major, I’ve never had one block or leak, but things can always be improved:
    1. They don’t admit that much air which reduces flow rate and can hinder tyres seating
    2. The little pip on the end can bend and break off
    3. You have to remove the core to get sealant in, and this can be hard when it’s gummed up.
    4. Conversely, if you want to undo the pip to let air out you can sometimes remove the core by mistake.
    5. Doesn’t always seal that well on the inside of the rim
    I love it when a bit of legacy tech is redesigned for the better, and even more when it doesn’t need anything else major to be changed.
    EDIT I take it back – forty quid a pair!
    Superficial
    Use Stans, have been tubeless for donkey’s years on several bikes (MTB and road). Never had a Presta valve clog, or break, or leak. The only issue is, as above, inserts can impede the air flow (which, realistically, just means a bit more pumping effort required).
    It’s worth pointing out that it doesn’t look like you can remove the valve core (for tubeless setup) on these?
    I don’t think I’m the target market for these things, but if some people find them helpful, that’s great.
    johnnystorm
    Are presta valves perfect? No.
    Are they £40 worth of imperfect? Also No.
    richmtb
    Can’t really argue with any of that. Most of the time I can seat a tyre with the valve cores in place and a high volume pump but this doesn’t mean that there is no room for improvement though.
    matt_outandabout
    ^ This.
    Kahurangi
    I’m resigned to replacing the gummed up presta valve cores on our mountain bikes every year or so these days. It’s one of the (small) prices of tubeless. I’ve forced the nut off the end of the thread, so that I can disassemble the core and give it a good clean, but that’s all a bit rubbish considering the price of a new, clean, intact core.
    Great that this also throttles airflow less – should make it easier to inflate tyres quickly to get them seated. Yes you can always remove the presta core to reduce the throttle anyway….
    Would I consider them on a new build? Yes (assuming <£10 each). Would I ditch the valves on my current wheels? No…
    trail_rat
    Been using stans on MTB since about 2008…..
    Using Stan’s on road bike since 2019…
    Clogging not an issue unless I’ve been lazy and not used the bike for a while. In regular use no issue. But tubeless has other issues when bikes don’t get used so it’s a minimal problem that’s easily resolved when sorting the other issues.
    malv173
    I really like the look of these. I’m sure anyone who uses Lezyne hand-pumps will too. No more random core removal by the trailside.
    jam-bo
    yeah. i learnt that the hard way…
    BillOddie
    Nailed it…
    desperatebicycle
    They ain’t even £20 worth of imperfect.
    thisisnotaspoon
    +1
    TBH I’m surprised it’s taken ~20 years since tubeless came out to develop a new valve.
    But £40? Lifetime guarantee or not that’s a lot.
    igm
    malv173
    The ABS valve on the Lezyne pumps sorted that removal problem.
    argee
    Looks nice, not sure it does much more than the current setup, but the one thing that would stop me buying these is that it doesn’t appear to be able to be used to pour sealant in, so would mean reverting to having the tyre off the rim a little, so unseating it and having the nightmare of inflating it up unseated and with sealant in it!
    oldnick
    FGF looks a bit thin this week.
    Still, I’ll enjoy fitting these whilst wearing my £450 dungarees.
    leffeboy
    If I want fancy valves I’ll use Milkit. Let’s you add more sealant without having to let your tyres down all the way so reduces faffage of reinflating problem tyres
    malv173
    @igm ah, mine had the screw on valves. Good to know for future purposes, I did like the pumps
    stwhannah
    @argee apparently you just pour the sealant in the same way as the air goes, no need to remove the valves – the space is apparently big enough to let your sealant through. I guess then you pump it up and that blows any remnants out the way?
    molgrips
    Its not £40 cos Presta valves aren’t free.
    scotroutes
    True. Only £36 then.
    chrismac
    Great idea massively overpriced
    scc999
    Don’t be coming in here stating facts.
    Just checked, DT Swiss valves 8.99 each (call it £18 a pair).
    Muc off £21.99 a pair
    Lifeline £9.99 a pair
    Schwalbe £16
    So comparing to the CHEAPEST ones I could see it’s £30 more. Compared to Muc off it’s 18 quid more.
    *If* they work as claimed and you suffer from any of the problems (I get gummed up valves, which can be a pain when you find out and need to pump up the tyre on the trail for example) then it may be considered an acceptable cost.
    But if you’ve never had an issue or dont care then the headline price is a bit steep.
    cookeaa
    A pair of ‘Lifeline valve from wiggle are ~£10 (and there are cheaper options too)…
    But the point still stands, are they ~£30 bettererer?
    Meh, I’d maybe pay £20 if I happened to need new valves, I wouldn’t go out of my way to pay four times the going rate for the slightly inferior extant product…
    chrismac
    True but I normally only replace the core which are about 50p
    thepurist
    If they sell I expect it won’t take long for someone to circumvent whatever bit of that is patented and whack out a cheaper version. Or if its Hope, a more expensive version in ano colourways.
    Stainypants
    I’m not sure this is the solution but Presta valves have no place on a mountain bike feels like the last hangover from road biking left they are fragile I once broke snapped 4 in a row on a ride in the lakes in the pouring rain it was proper grim and now with tubeless they are prone to blocking. If you were start with a blank sheet of paper you’d never come up with the Presta valve, it should go the way of quick releases, rim brakes and threaded headsets if you ask me.
    molgrips
    They’ll come down, I doubt there’s much you can patent about valves so there’ll be loads of redesigns on the market soon.
    bornonaboat
    The other option is just to fit Schrader tubeless valves, options include Nutrak, Stans, Joe’s etc etc.
    Easy to run a drill through the valve hole I. The rim if it is presta only. Carbon excluded obvs.
    Stainypants
    We have tublesss Schradar valves, why did Presta end up being the tubeless standard, was it because they had a more readily/commonly removable core. When I camee back to MTBing in the early 2000 most rims where drilled for Schrader with a adapter for Presta.
    ndthornton
    Better – but still less good than Schrader (2 of which can be had for £9)
    I don’t buy the not needing an inflator claim, I dont see how this makes any difference at all to seating tyres; consequently, if I cant remove the valve core will it work with my ghetto tyre inflator, probably not. Also the ‘dust cap’ is integral part of the system now rather than an annoying thing its fine to lose.
    argee
    Hannah Dobson
    @argee
    Will be interesting to find out how you get the sealant in without a removable core, i’ve got a syringe and the bottle to fill up through the presta valve minus the core, wonder if reserve have got a clever injector as well that screws on, as it must have to push down on the core to open the valve, as well as allow fluid to pass around it?
