Home Forums Chat Forum Expensive things that are a bit rubbish
Viewing 40 posts - 81 through 120 (of 139 total)
  • Expensive things that are a bit rubbish
  • edhornby
    new build houses
    genuinely not being snobby about this, there are lots of things that can be done better for very little cost difference (I’m thinking solar panels being a requirement for all new builds, thermal standards etc)
    molgrips
    Most new builds around here seem to have them – I thought there was at least some kind of incentive..?
    You seem upset, did I take your turn?
    No, just pointing out your silly troll 🙂
    mrmonkfinger
    Dyson, rubbish?
    We were given an old DC04 (?) that didn’t work (as it “didn’t have any suck and always stops working after five minutes” – it was just blocked up, because it had never had the filters cleaned or the U-bend cleaned – so the motor overheated and tripped)
    I washed the filters and cleaned the blocked tube. That was about six years ago. It still works perfectly.
    Expensive it might be but I can’t say it’s a bit rubbish.
    mrmonkfinger
    Making the rooms big enough to swing a medium sized cat in would be a start.
    molgrips
    In order to do that you need more land, which makes your house very much more expensive. Or you build three storey houses, like mine.
    tomhoward
    that must add up
    Yes it does, but given that the thread is for things that are expensive and rubbish, your point is somewhat invalid. Bikes are ace. Not rubbish.
    MTB Marathons.
    £35 to ride on Public Rights of Way?
    willjones
    Dualit toasters.
    Ours is 31 this year, just treated it to first set of new elements (One side of one of them was toasting unevenly, but still just about working).
    franksinatra
    Paris Hilton
    ourmaninthenorth
    Dualit toasters
    Ours was second hand to us 10 years ago, where it had come from several years’ service in a works kitchen. Barely even cleaned it, let alone had to repair it.
    It’ll probably blow up now.
    Tom_W1987
    doesn’t get much more expensive or much more useless than this
    Nukes stopped the cold war from ever going hot, if there had been no nukes, Russian T-55’s would have stormed accross Europe a long time ago.
    Nuclear war makes large scale industrial war between developed nations a losing proposition for both sides, without them, one side will always believe that they have a chance of gaining something from war.
    Solo
    Yeah, new builds. Shyte !
    Ever increasing prices, still shonky planning, workmanship and finishing.
    mikewsmith
    MidlandTrailquestsGraham – Member
    MTB Marathons.
    Signs, maps, prizes, organisation, marshalls, first aid cover?
    Leku
    These would CSH level 3 dwellings built under May 09 guidance. Now most are built using fabric first approach and thus no renewables.
    mrmonkfinger
    IIRC three storeys makes for lower heating cost compared to the same floor space on two storeys.
    Guess you lose some floor space with the extra stairs.
    SammyC
    @Harry, our Dyson does that (cuts out all the time) and its because the battery is a bit loose. Slam it with your hand, so that the battery goes completely back in, and its perfect again.
    It’s a bit annoying but I just like to pretend I’m slapping in another magazine before taking down some more mofos*
    *raisins, toast crumbs, rice crispies etc
    deluded
    Agree with OP re Dyson’s.
    Poor build quality and about as much suction as a 200 year old emphysemic tortoise using a straw with holes in – utter gash. Well ours is anyway.
    surroundedbyhills
    IT Departments!
    *ducks*
    molgrips
    Meaning what?
    I think all houses should be three storeys. 50% more floor space and no downside. Our house takes up less floor space than the normal 3 bed semis in neighbouring developments, but has two big bedrooms and one good sized, rather than two small ish and one unusable box room. Has a big living room too.
    mr-potatohead
    anything with crank brothers written on it
    brooess
    Pretty much all London property. Until the bubble bursts of course
    dragon
    Dyson’s how is no bad actually a good design feature, just means the dust escapes when you empty it. Apart from the fact their build quality is completely variable.
    Audi A3, not as good as the VW Golf despite essentially being the same car for more cash.
    Merino wool baselayers.
    Austin Reed shirts.
    unknown
    Only on STW do you get willy waving about toasters!
    simons_nicolai-uk
    Insulate beyond building regs, focus on airtightness, effective windows and doors.
    Code for Sustainable Homes is a well intentioned but poorly designed standard that creates some perverse incentives. There are too many ‘points’ for renewables so they’re not a requirement but it’s easier/cheaper (and requires fewer changes to the way they build) for housebuilders to just stick some solar panels on the roof.
    Likewise the EPC energy performance rating. As I understand impossible to get an A rating without renewables, even if you’ve no requirement for heating (completely passive).
    molgrips
    Encouraging then – our neighbours have put their house on the market and it’s been given a B rating.
    Do they test this or look at your bills or something?
    Yeah, considering the number of riders you see on these events, compared to the number of riders you see on exactly the same PRoWs on any other day of the year, I guess that list must be an important requirement for a lot of people.
    For some of us though, it’s just £35 to ride on bridleways.
    Same goes for sportives and public roads.
    toby1
    surroundedbyhills – Member
    IT Departments!
    *ducks*
    Careful now!
    ps – I really like my not that old Dyson and Dualit products.
    Parliamentary democracy
    simons_nicolai-uk
    Paper exercise based on what is meant to be installed and a lot of assumptions. Takes no account of how well it’s done (eg is the insulation tightly butted and taped or just thown in?) or actual energy use.
    zoo200
    HS2 it’s gonna cost lots and still be delayed and late.
    Harry_the_Spider
    SammyC – Member
    Thanks, I’ll try that.
    Lock n’ Load!
    Solo
    Lock n’ Load!
    I’d suggest NOT slamming the thing with your fist, but slightly shimming the gap between battery and its retainer / lid, whatever.
    mintimperial
    Cars. Expensive and rubbish. I resent spending thousands of pounds on something I have to drive to get to boring meetings, usually through interminable traffic jams and roadworks, surrounded by thousands of rude, selfish idiots.
    I realise that this is something of a minority viewpoint, however, and nearly everyone else in the UK thinks spending vast chunks of their hard-earned on something that makes them angry and fat is just brilliant. Ho hum.
    molgrips
    Cars aren’t rubbish, it’s your lifestyle that’s rubbish.
    Cars, as objects, are absolutely incredible things, and given how much work has gone into each one it’s amazing how cheap thye are. You just listed a load of problems with modern life, not problems with cars.
    PS cars don’t make you angry and fat – you make yourself angry and fat. Cycling is just one way to make yourself thin and happy, there are others.
    brakes
    if you read too much molgrips you’ll become angry and fat
    bikebouy
    Jamies Restarants.
    Overpriced grilled veg and pasta 🙄
    badnewz
    Modern Life is Rubbish!
    mrmonkfinger
    not many credible alternatives around, though?
    Buy an older one, spend less money. You can buy some decent old cars for very little money.
    MoreCashThanDash
    Women! Just when you think you’ve found a reliable and economical version it starts producing children ffs!
    aracer
    17 year old Dyson which still works just fine here – it was certainly a step up on anything else available at the time.
The topic ‘Expensive things that are a bit rubbish’ is closed to new replies.
