Well technically Time cleats, but same thing.
I tried an aftermarket shim to try and address a leg length discrepancy which results in right leg over-reaching and left ITB getting tight as a result.
Problem is the aftermarket shims are quite ‘short’ so it leaves a very obvious step on the sole of the shoe which the pedal gets hung up on, cue much faffing, swearing and stamping trying to get cleat back in.
I’m thinking about butchering a sturdy tupperware box to create shims that are the length of the channel in the shoe and glueing (or even using short self tappers) to hold them in place, just wondering if anyone has tried similar?
Ta
