DIY help, door and ...
[Closed] DIY help, door and insulation
4 Users
I'm insulating the loft room and have put 70mm between the rafters and taped the seams up, but now that I'm planning the additional 50mm plus 10mm plasterboard I realise the door is going to need a second thought. It's already a bit short and narrow so I'd be reluctant to just make the door smaller.
What would you do? There's about 20mm space at the minute.
U could leave that one surface at 70mm of insulation and just plasterboard it as is.
I could make the door open the other way and take a bite out of the corner.
I could leave a small panel of the wall at 70mm insulation and just insulate the rest, and try and make the recess look acceptable.
Anything else?
Posted : 12/01/2017 11:09 pm
Good job so far, rehinging the door with a bite our or using a sliding door are the options I'd use. 120mm total is about R3. You should be aiming at R5+ for the roof so it still won't be warm up there. I doubt the wall is better than R1 so 50mm (ideally 100mm) and plasterboard on the wall too if I were doing it.
Posted : 12/01/2017 11:21 pm
Sliding door.
Posted : 13/01/2017 7:31 am
Any option to move the door further in to the middle of the room?
I don't know what's on the other side of it so can't judge!
Posted : 13/01/2017 10:19 am
There's nowhere to put a sliding door or move it unfortunately [img] [/img]
Posted : 13/01/2017 3:02 pm
