Home Forums Bike Forum Cycle lane etiquette – new driver question
Viewing 40 posts - 81 through 120 (of 215 total)
  • Cycle lane etiquette – new driver question
  • stevemtb
    I think TJ is spot on with his assessment a few posts above. On the road pictured a safe overtake of a safe cyclist is going to take them well into the opposite lane so no problem with 2 abreast.
    For the debris in the cycle lane, it’s not so much how often it’s swept, it’s the amount that’s cleared by car tyres. A lot will stick to (or in) them that could damage a bike tyre or get flicked off the main road – straight into the cycle lane. The cleanest part of the road to cycle is usually where the car tyres line up.
    Lifer
    cynic-al – Member
    really? I wonder if a driver could see past 2-abreast to see an oncoming cyclist.
    Can you see past cars before crossing the white line to overtake?
    cynic-al
    Yes, they have glass at eye level.
    grum
    The highway code doesn’t agree.
    butcher
    That depends on how you interpret it. The highway code isn’t very clear, I’d say.
    I kinda read it as, treat it like car, move into the other lane and overtake properly…rather than stating a distance, which in some instances may well make it impossible. I think it’s intentionally vague.
    grum
    It’s pretty clear in saying that you shouldn’t ride two abreast on busy roads, which it sounds like this was.
    GrahamS
    I would not use the bike lane if there were parked cars – you need to be more than a metre away from parked cars at all times to avoid being doored. basic defensive cycling. … I would not ever go into that metre of safety between me and a parked car
    Personally I think this is a bit hard line. If you are approaching parked cars on a long straight road then you’ll be aware of cars that are clearly parked up and empty (by seeing them at a distance, seeing no peds near them, and seeing no one through their windows). If I had traffic behind me I’d use that point to move into the “door zone” and let them past.
    (Edit: can’t be arsed with the two abreast argument again)
    TandemJeremy
    Graham – sorry but you are wrong on this. Its another basic defensive measure – always go wider than a metre from a parked car. See yesterdays thread about making cycling safer – being doored by someone in a parked car is a common injury.
    I look in every car – every one – as well – a metre is barely enough if somone opens a door. You cannot always tell for sure with headrests, tinted windows etc if a car is empty.
    By riding in this way you do not hold up cars at all in any way they will be in the same place in the next jam.
    If you go into the door zone you are foolish and putting yourself in unnecessary danger.
    You may consider my attitude hardline – I consider yours very dangerous. You are removing your safe margins and allowing cars to squeeze past in a dangerous manner.
    Edit – you also need the space to give you somewhere to go if a car does try to squeeze past – same as if you are riding along a stretch with barriers – you ride wider as you cannot escape off the road
    oldgit
    Just to say I’ve not read much past the first few posts. But are you sure what you’re looking at is a cycle lane?
    There are loads round here on the busier roads. They’re about the width of a cycle lane, but they just mark the edge of the carriageway.
    Lifer
    grum – Member
    Should/should not is advice must/must not is legal requirement.
    Agree with TJ on road positioning too, better to leave space inside you than have no-where to go.
    mk1fan
    cynic-al – Member
    Serious Q: riding 2 abreast and 1m+ from parked cars, would cyclists actually be allowing drivers enough room to overtake them safely (while giving parked cars on the other side 1m of room too)?
    I’ve said it before and I’ll say it again. That photograph is inaccurate, deceptive, plainly wrong and should not have ever made it into any official / legitmate information about road safety. Everything about it is wrong.
    aracer
    Explain to me exactly what’s wrong with it and why.
    Anyway, if you’re going to complain that is wrong I feel obliged to point out that IMHO the advice about not riding two abreast on busy roads (as cited above by those who think cyclists should get out of the way of the “traffic”) is also incorrect and dangerous, as singling up in such situations is likely to encourage drivers to squeeze past.
    mk1fan
    My post was about the photo not what was writen. Unfortunately, or thankfully, I don’t know how to just quote the photo.
    For completion though;
    1. That is not the space you’d leave if you were overtaking a ‘car’.
    2. That is not the road position you’d take if you were overtaking a ‘car’.
    3. The overtake is being performed right after a roundabout at which point you’re 99% unlikely to have been able to properly assess an overtake of a ‘car’ – unless you weren’t paying attention at the roundabout.
    4. The car is still on the same side of the road not leaving enough clear space for a ‘car’.
    5. The attitude of the car is such that it is clearly not settled / under full control therefore demonstrating that the driver hasn’t planned the overtake.
    6. The car is still ‘moving out’ to do the overtake even though it is level with the cyclist.
    Incredibly basic and simple stuff.
    The fact that the photo has been thought out and staged just demonstrates how little road skills are considered.
    aracer
    Well make your mind up – is it too far out or not enough?
    I don’t see any problem at all with overtaking a bicycle there though – and the HC doesn’t suggest you shouldn’t overtake cyclists in locations where you wouldn’t overtake cars. Though in actual fact I don’t see any problem with overtaking a car there either if the driver of the overtaking car is concentrating properly – if you start looking at the overtake as soon as you’re clear of the roundabout, then you’d easily be able to safely be making the overtake at that point.
    Now you’re just being silly. How do you get that from the photo? I see no tyre smoke, skid marks or exaggerated body roll. Sure it might not be totally level with the horizon, but if you’re suggesting that shows it’s not under full control you’re really grasping at straws – you reckon you can tell from that picture how much camber there is on the road and how much the camera is distorting the perspective? Are you also suggesting that the car should overtake without any lateral acceleration at all?
    Is it? Skidding sideways you think? Because otherwise it’s hard to see how it’s moving out when the front and rear wheels are parallel with the white line (to the level of accuracy you can derive from that photo).
    GrahamS
    I completely agree with that part. I just think the absolute “never” is hardline.
    IMO sometimes it is quite possible to determine that the cars parked up are in fact empty, and you can then safely choose to enter the doorzone to allow folk past.
    For example as you approach you see the driver get out, lock the car and walk away. Or the car could clearly have been there for a while (maybe covered in leaves, rain, dust, snow). Or as I said you may be able to see through the windscreen and clearly see it is empty.
    If there is zero chance of getting doored by a car then I’d be happy to pass it in the doorzone to let someone pass me.
    It is likely to be less dangerous than frustrating the driver behind me.
    Not on the OPs road, where there is a cycle lane and plenty of room for cars to pass bikes using that lane without any squeezing.
    In fact, looking at that photo I’d say you could easily ride 1 metre from the parked cars and still remain well within the cycle lane. So I’d probably ride the whole thing with my wheels just inside the lane.
    cynic-al
    Eh? the overtaking car would be nowhere near giving the cyclist as much room as the HC pic above…aren’t you a proponent of the latter?
    Gary_M
    Here’s a wee update following this morning ride. I set a lap on my garmin for this section.
    Total distance is 0.34 miles from one set of lights to the next; this took me 51 seconds to ride this morning. As usual there were cars to the left of the path and as usual I didn’t ride in the path. To say ‘But…there was a pretty wide and completely clear cycle lane just to the left’ is nonsense and certainly isn’t ‘pretty wide’.
    As others have said even if the riders were single file in the path your would still have had to wait for a clear section of road on the other side before overtaking. So them riding two abreast made no difference to you or the progress of your journey.
    If someone is riding in a cycle path a vehicle is still obliged to give space when overtaking.
    I’m surprised that as a new driver you are totally unaware of how you should safely pass a cyclist. If that’s the standard you can pass a test at then I’m worried.
    eat_more_cheese to be fair the cycle path has been swept recently, well as far as floak which is east ayrshire side. There’s glass on the donwhill section to Fenwick (from Glasgow) and glass on the bit at the top of newton mearns, apart from that it’s okay.
    Out of interest what time are you on the path – we must pass each other often.
    As for my comment about groups using the path being a pain to riders approaching from the rear, firstly I’m glad it amused you, secondly I’ll either go on the road to go round, or wait until they move over, and lastly I certainly wouldn’t post about it on a forum. I apply common sense, patience and courtesy as I fully accept this is a shared path for walkers, cyclists, horses, runners, etc.
    Gary_M
    No there isn’t.
    butcher
    It is hardline, and you can never say never, but let’s say there’s a small child lying on the back seat. Mummy locks the door because she doesn’t want little Timmy kidnapped in the 5 minutes it will take to pick up the dog from uncle Dave’s. But little Timmy can open the door from the inside, he reaches for the handle, and…oops.
    Far better places to pullover before letting any traffic past.
    peterfile
    Gary, the A77 is quite a long road as I’m sure you are aware. I didn’t sit on google maps clicking until I found the exact spot I encountered the cyclists. That’s the approximate area – however as you know, the markings and road lay out are the same.
    I know perfectly well when it is safe to pass a cyclist, which is why I didn’t drive into the path of oncoming traffic trying to get past them.
    You really don’t come across well at all. Try changing your tone or stop being so condescending if you want people to take anything you say seriously
    GrahamS
    No there isn’t.
    Looks fine to me, as this crudely shopped image shows:
    How much space do you want FFS?
    butcher
    That car’s gonna loose a wing mirror if he doesn’t serve back in…
    Cyclist is still borderline in the door zone too.
    GrahamS
    Only if traffic the other side is driving hard against the centre line too.
    That’s where I’d ride it. Far enough out that that someone would have to really fling the door open as wide as it goes to catch me, but still in the lane with plenty of room for cars to pass easily.
    Gary_M
    You can post as many pics as you want but showing a random part of a path doesn’t represent the issue. Go and ride it then come back with your finding.
    To pass a cyclist or obstacle on the other side for example. I ride a wee bit further out on that section, there’s a few junction and parked cars obscure visibility for drivers joining the main road, the cars tend to stick out of the junction and if you don’t ride a bit further out you wouldn’t be visible.
    You really don’t come across well at all. Neither do you to be honest, you appear annoyed that someone who knows the road has come along and spoiled your party. Do you have a grudge to bear or something, ah I know why?
    You’re an inexperienced driver and have a lot still to learn. Taking umbrage at advice won’t help you. You appear to be the only one with taking issue with my posts.
    GrahamS
    That was the photo the OP posted as representative of the issue.
    If it is different along other stretches then fair enough, but I though I/we were discussing this stretch?
    peterfile
    Neither do you to be honest, you appear annoyed that someone who knows the road has come along and spoiled your party. Do you have a grudge to bear or something.
    No grudge at all. I asked a simple question about cycle lane etiquette, it’s not really what I’d consider a “party”.
    Your posts contain some good, factual points, but then you do stuff like this:
    if that’s the standard you can pass a test at then I’m worried.
    which is such a pointless and predicatable jibe, it undermines the good stuff that you post.
    I’m quite aware of this, which I why I drew it to everyone’s attention in the thread title.
    What was your advice exactly? Was I incorrect in my action (i.e. sitting behind the cyclists until I considered it safe to overtake)?
    Gary_M
    So did I GrahamS but apparantly not. There’s also a jinction just up ahead so the vehicle shouldn’t overtake there anyway. As I said, its a 0.34 mile stretch of road between two sets of lights, from experience very few vehicles even bother to overtake there.
    Pass when its safe to do so, giving the cyclist plenty of room, so on this stretch of road you would need to move to the other side of the road whether there was one cyclist or two.
    I presented the facts which were different to your version of events, you appeared to be annoyed by this. Perhaps you need to adjust your tone so you don’t come accross as so defensive?
    grum
    In the real world, riding single file where GrahamS’ picture shows would be absolutely fine. If there still wasn’t room for someone to pass and you were holding up traffic you could have a quick look at the parked cars to see if there was anyone in/around, then pull in a bit, or pull in where there were no parked cars. Riding single file means cars can get round (still perfectly safely) quicker/easier. It wouldn’t even have much impact on your Strava KOM attempt.
    Of course things are very different in self-righteous ‘why should I ever inconvenience myself in any way whatsoever’ cyclist world though.
    Two cyclists abreast means you have to pull completely over into the oncoming lane, meaning a larger gap in traffic is required, thus holding up traffic completely unnecessarily (and going against what the highway code says about busy roads).
    GrahamS
    Well said grum
    grum
    If we are going to have any kind of sensible relationship between drivers and cyclists in this country it needs to be a two way street (no pun intended). Not cyclists screaming ‘WHAT ABOUT MY RIGHTS’ and being completely insensitive to any other road users.
    peterfile
    This is exactly what frustrates me with your posts Gary.
    How can you present different “facts” to what I experienced?
    It’s all very simple – I was sitting behind cyclists riding two abreast in busy traffic on the A77 in the area where I posted a pic. I asked whether there was a reason for them not using the cycle lane available – somone pointed out quite quickly that it was most likely due to risk of hitting an open door.
    I don’t really know why you felt you had to time yourself on the route and post it here – it doesn’t really add anything to what I asked.
    Gary_M
    wow, it takes less than a minute to ride this bit of road, the phasing of the lights means that cars are going to be stopping anyway, bikes are always quicker on this stretch than cars, so overtaking is a pointless excercise.
    If you’re generalising then thats fine, but your reasonong doesn’t make sense on this particular stretch of road. The only section with no cars is the junction, in the mornuing cars are tightly parked so difficult to see if there is anyone in them, the only safe option is to ride outside the path.
    But…there was a pretty wide and completely clear cycle lane just to the left (part of the road)
    The cycle lane isn’t pretty wide and it’s not suitable for riding in safely.
    The timong of the route was to demonstrate that this is a very short section of road. Whats wrong with adding some detail?
    irc
    Here’s an cycle farcility near me which is similar to the one being discussed. As this picture shows a cyclist needs to be riding with his wheels on a line a minimum of 1.5m away from parked cars to avoid doorings. I prefer 2M
    It annoys drivers but better that than
    this.
    GrahamS
    Couldn’t see you piccy irc. So fixed it:
    Edit: Oh no I didn’t. Grrr. I guess they don’t like external hotlinks.
    Here it is:
    http://www.crazyguyonabike.com/pics/messages/00/04/06/00/small/cyclelane.jpg
    Edit 2: And now it is being actively blocked. Oh well. I guess http://www.crazyguyonabike.com didn’t want the traffic.
    FWIW I agree dooring is a serious risk.
    butcher
    Comments like that are quite annoying. Inconvenience? I find riding on any but the quiestest of roads an inconvenience. It’s not something I do for enjoyment, and I certainly wouldn’t hold any cars up for the sake of it.
    I would probably even ride the position Graham has kindly mocked up in photoshop, as and when I felt it safe to do so. But Graham knows as well as you and I that there will be at least one car hanging out a foot from the curb parked at a jaunty angle, forcing you negotiate your way back into the line of fire.
    At the same time, you guys also know some people will give you that much space (there’s some good drivers out there too). Many will give you much less and pass worrying about their wing mirrors more than they worry about you.
    We also all know about the perceptions on the road, the perceived seperation that a cycle lane like that creates, and reasons for riding primary and secondary position.
    I wouldn’t chastise anyone for riding in that position, it’s not terrible. I believe it’s safer further out into the road, and I don’t think that should be chastised either. Safety is important. And if that’s what it takes to make a cyclist feel safe, so be it.
    Speaking as a driver, sometimes I would prefer people to take a stronger road position. The time I lose is minimal, and it also means I feel LESS pressure to overtake. So in some instances it actually makes me feel more comfortable as a driver.
    If someone’s in the cycle lane, even if they’re hovering on the line with their elbows hanging out past you, some people can’t understand why you would hang back when the biggest gap you can possibly leave would be measured in centimetres.
    gwj72
    Piss funny how I return to check out this forum after a year and the exact same arguments raging.
    It’s pointless. No matter what rules (laws, road rules or etiquette) you place on drivers or cyclists, we all know there will be a significant number of both that ignore them.
    On “doorings” – have you tried using your eyes and looking to see if anyone is in the car and about to vacate? always worked for me, you can have that tip for free 😉
    GrahamS
    Yep, but it often isn’t possible.
    On a long straight road where you can easily see into cars then yes (as I mentioned above).
    But if there are a lot of cars and you’re doing a decent speed whilst keeping an eye on the other traffic, watching side roads and dodging potholes then you might not have time to do a proper check, particularly on cars with tinted windows or no rear window.
    Hence why avoiding the doorzone is good general practise.
    gwj72
    I’ve past at least a squillion cars, over 20 odd years, at less than 1m distance and not hit one yet using my patented “look and see” method. Even though I am travelling much quicker than a cyclist with much more to obstruct my view and just as much on my mind and less time to take decisions.
    You too can use “look and see” on a royalty free basis. I’ll set a website up with instructions and do some presentations in community centers and public toilets in parks.
    GrahamS
    Erm… so what are you travelling in exactly?
    gwj72
    a car?
The topic ‘Cycle lane etiquette – new driver question’ is closed to new replies.
